RV.Net Open Roads Forum: Tech Issues: Dedicated Battery to power cooler, solar re-charged
 > Dedicated Battery to power cooler, solar re-charged
obiwancanoli
Napa
Posted: 07/15/21 12:21pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks
CA Traveler
The Western States
Posted: 07/15/21 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
You usage is not obvious: a few hours, 24/7, etc. The SUV plug can power the refer but not battery charging. You'll need larger SUV wiring and/or a DC-DC converter and both have losses. Plus some newer vehicles don't fully charge the vehicle battery - rather reduced charging to help with the EPA mileage. In addition the alternator and vehicle battery are close which is part of the charging design. A remote battery - thinking in the back - ie the starting battery is charged while the remote battery not so much.
Consider a DC-DC converter that can be set for Li or AGM or whatever battery type and alternator load.
2014 Grand Cherokee Overland
Bob
Posted: 07/16/21 04:32am Link  |  Quote  |  Print  |  Notify Moderator
Setting up a solar system is very straight forward
Solar panel----Solar Controller----Battery----Load (See note)
The load may also be connected to the controller depending on the max current draw.. The configuration above is in my "Living room" running a radio.
It is the one the battery maker suggested
I would recommend a LiFePo4 battery for reasons including the one you stated.
Advantage of connecting load to controller: Low voltage protection
Advantage of LiFePo4.. You might not need low voltage protection
Disadvantage of solar: If battery is not big enough cooler may cease to cool due to low voltage. This happens with LiFePo-4 very late in the discharge cycle (like below 10%)
mr_andyj
Georgia
Posted: 07/17/21 10:00am Link  |  Quote  |  Print  |  Notify Moderator
Mount the battery close to the fridge. Run the fridge to the battery to get power. Super easy.
For charging use a solar charge controller connected to your new solar panel.
Also, connect it to the vehicle alternator for when you drive. Use a solenoid switch so it is electrically connected to the alternator/starting battery when the motor is running and when ignition is off the switch turns off. Hint, you can use the radio ignition power feed to tell the solenoid switch when the vehicle is on/off.
For charging off of shoreline you can put a switch to connect it to the coach batteries that are being charged, or you can add a new charger just for your fridge battery, and when it is powered from shoreline it will charge.
