RV.Net Open Roads Forum: Tech Issues: replacing pigtails on propane tanks
 > replacing pigtails on propane tanks
Old-Biscuit
Verde Valley
Posted: 07/15/21 09:57am Link  |  Quote  |  Print  |  Notify Moderator
StirCrazy wrote:
rvshrinker wrote:
thank you that is so helpful!
This article suggests yellow tape is the preferred sealing method and adequate:
https://www.oasisngv.com/vdb/document/1179
actualy it doesnt, it says it is more conventiant for the worker to use as it is easier to carry , doesnt have a shelf life, and has no cure time. if you dont wrap it properly it can be the worst one you'll use.
I used to work for a gas company when I was a young lad and we would have been fired for using tape instead of liquid sealers. if you notice when the rv's come from the factory they use a liquid sealant also. the choice of liquid sealants is just as important though, you want to get a non hardining one, so it sets up but doesnt harden like a rock.
Steve
Liquid sealers are fast/easy ....just a quick wipe around the threads with the brush----Done
Yellow Gas Tape is just as effective and less messy.....just a couple of wraps in the RIGHT direction...done
Direction is important where as with liquid sealant---just swipe it on
Commercial/Production----time is money....liquid sealant is the choice
Yellow tape is good also.
US NAVY------USS Decatur DDG31
Posted: 07/15/21 11:15am Link  |  Quote  |  Print  |  Notify Moderator
Yellow gas pipe tape is just fine for npt threads. Not sure where that wives tale came from.
Or pipe dope. TAke your pick. Heck electrical tape will work in a pinch.
Thread is generally 1/4” male flare or 1/4” mpt. Just replaced one on our 2017. Fwiw the great camping world didn’t have the right one. Should have just gone to the hardware store in the first place.
2017 Heartland Torque T29
rvshrinker
Beautiful Pacific Northwest
Posted: 07/15/21 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
what is the RIGHT direction?
time2roll
Posted: 07/15/21 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
The correct way should wrap the tape around as you are turning in the direction of tightening the male fitting. You will be Turning to the right as you have a right hand thread.
675w Solar pictures back up
Old-Biscuit
Verde Valley
Posted: 07/15/21 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
Hold item so threaded end is to your right....
Then start wrap on threads AWAY from you
philh
Belleville MI
Posted: 07/16/21 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
Old-Biscuit wrote:
Yours could be NPT or Inverted Flare (check which in the LINK above)
If old hoses screw directly into REG body then NPT
If old hoses screw into a brass adapter on REG then Inverted Flare
Yellow Gas Tape on NPT...not on Inverted Flare
Tighten until you feel good resistance ....
No washers used.
My first TT was used, and the Community College Plumbing / Certified Master Plumber had installed a new water heater.
Propane line (flare fitting), not only was loose enough to start a fire, but even better, pipe dope spread on the flare fitting.
