RV.Net Open Roads Forum: Approximate fuel milage of these 2 motorhomes?l
 > Approximate fuel milage of these 2 motorhomes?l
wolfe10
Posted: 07/14/21 07:47am Link  |  Quote  |  Print  |  Notify Moderator
aswagerty14 wrote:
We are choosing between 2 motorhomes and it is coming down to fuel mileage, does anyone know about how many mpg these 2 would get and would the difference be significant enough to make it the decision maker? Holiday rambler diesel 5.9 L or Fleetwood pacearrow gas Ford 460 both on 37 ft class a's. I know the diesel will get better fuel mileage but by how much? Thank you!
While I agree that MPG is not at the top of the "why to buy a coach" list, there WILL BE a significant difference in MPG between a Cummins B and the old Ford 460 in a heavy coach.
I would venture that the heavy gas coach (37') would use about 40% more fuel.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
RLS7201
Posted: 07/14/21 07:52am Link  |  Quote  |  Print  |  Notify Moderator
That ol 460 is about as bad as it gets for fuel mileage. You can count on 7 MPG @ 62 MPH. On the other hand, I have read reports on the 5.9 getting 9-11 MPG.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
Horsedoc
Dixie --- N. Georgia
Posted: 07/14/21 08:04am Link  |  Quote  |  Print  |  Notify Moderator
If I could have found a handicap diesel coach that is what my gasser we have today would be. Diesel chassis just seem to ride and handle better to me.
Long distance traveling, give me a diesel any day.
We have crossed the country several times in a diesel and mileage varied. Had a 300 Cat engine and on one trip across, east to west, we got great mileage 12+ . Same coach, engine same towed we got just a bit better than 5. Difference? We drove into a strong headwind all day long.
Tal/IL
Central Illinois
Posted: 07/14/21 10:00am Link  |  Quote  |  Print  |  Notify Moderator
Here is our experience with 3 class A m-homes. I keep a log of fuel usage, and fuel mileage is averaged over several thousand miles for each. Fuel usage does include some generator run time:
33' gasser with 454 engine @ 16,000 lbs max - 8 mpg
35' gasser with V10 engine @ 22,000 lbs max - 7+ mgg
40' diesel with 400 HP Cat C9 @ 31,000 lbs max - 6.4 mpg
35 miles from Normal, IL. As close to normal as I'll ever be.
2006 Country Coach Inspire Genoa 40ft
wolfe10
Posted: 07/14/21 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
We may be a long way from guidance for the OP.
Pretty hard to compare an older (much lighter)coach with 5.9 liter Cummins B with a heavy 40' with 9 liter meeting much stiffer EPA requirements.
I promise you, a reasonably driven reasonably light coach with Cummins B can get 10 MPG on level and 9 in hills. Want to drive 70 MPH? NO WAY to get 10 MPG.
Mommalu
Mpls. MN
Posted: 07/14/21 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
We have the 5.9 in a 40' coach, always drive with full water of 80 gallons and always do the 70 mph speed limit on the interstate. Even with a good head wind the lowest we have ever gotten is 7.9 the most 8.9.
We had a 32' V10 we drove the same and mileage was between 5.5 to 7.5, it was all over the road, a rough ride and a screaming engine that put out so much heat we often had to drive with the genny and the roof A/C on. Once stopped the heat from the drive shaft would heat the floor from engine to the rear wheels, even with both A/C's on it was hard to cool the interior down.
Happiest day was trading in the 2014 and buying the 2007 diesel. Granted with an older coach there are things to update. However its a joy to drive, we talk now no more shouting, no more jarring bumps.
Just my 2 cents.
dodge guy
Bartlett IL
Posted: 07/14/21 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
Having a 2012 F53 with the V-10 and getting 6mpg towing a 13 Explorer. The 460 F53 will not be much less in mileage, less HP yes, but not mileage. Not by much anyway!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
et2
MI.
Posted: 07/14/21 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Had a Fleetwood expedition with the 5.9 Cummins. 68 MPH always got 10 plus. Now 45’ tag Discovery with 450, 6.4 the best so far
kedanie
Albuquerque, NM
Posted: 07/15/21 08:25am Link  |  Quote  |  Print  |  Notify Moderator
Basically, if your worried bout the fuel mileage you can’t afford it.
Keith
Keith and Gloria
2013 Tiffin Phaeton 36GH
2012 Jeep Grand Cherokee Overland
USAF 1968-1976 Vietnam Veteran
atsrmf
Indio
Posted: 07/15/21 09:39am Link  |  Quote  |  Print  |  Notify Moderator
All things being equal I would take the diesel.
