RV.Net Open Roads Forum: Class A Motorhomes: Meter
farmingdad
ky
Posted: 07/13/21 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
Does a guy need a meter to check his exhaust temperature.And turbo boost. I notice my heat goes from 180 to 215 when I get on steep grade. Isx 600
Flute Man
Payson, Arizona
Posted: 07/13/21 10:18pm Link  |  Quote  |  Print  |  Notify Moderator
Probably not too abnormal. Keep the RPMs up very high when you’re going up a steep hill also if your radiators a bit dirty it can cause an increase in temperature. If the engine coolant hasn’t been changed in the last 3 to 5 years that can aggravate the situation.Mine is done the same thing on steep hills. The important thing is to keep the engine RPM up high very high to keep the water circulating good.
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
Posted: 07/14/21 05:37am Link  |  Quote  |  Print  |  Notify Moderator
IT would not hurt but... The question is how much it would help.
Now a processional highly trained Operator (Not just a driver) Might (or not) know the meaning of the readings... My brother was both a Semi Owner/operator and a diesel/gasoline mechanic I'm not that good with Diesels. He likely would know what an out of range reading meant. and what the normal range is. I don't.
So the meters MIGHT be of benefit to him. NOt to me without further research and study.
Since I do not know what you know in this regard The best I can do is guess. And my guess is your knowledge of the meter readings is closer to mine than my professional operator brotehr's.
Ivylog
Blairsville, GA and WPB, FL.
Posted: 07/14/21 06:57am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you are letting the Alison do the driving…put it in D and push the right pedal. A Alison 4000 will lug a 600 ISX… will not down shift until below 1400 rpms which is fine in hilly terrain BUT not when climbing a mountain. You need to manually downshift and keep the rpms above 1800 when climbing for more than 2 minutes. Doing this should keep the temp below 200 and the exhaust temp well below 1200…if you’ll downshift you do not need an exhaust temp gauge. I’m surprised you do not have a boost pressure gauge on the dash.
Sold 04 Dynasty to our son after 14 great years.
Upgraded with a 08 HR Navigator 45’...
farmingdad
ky
Posted: 07/14/21 07:23am Link  |  Quote  |  Print  |  Notify Moderator
No it doesn’t have a boost gauge. My Monaco did This is on Spartan. I deleted It an notice heat moves a little more don’t think in danger zone I hope not. I’m wondering about putting a 180 thermostat in
bob213
Fresno, CA
Posted: 07/14/21 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
In my experience, unless you are running a "tune" your engine computer should automatically de-fuel when ET"s get excessively high. Boost and EG functions are commonly over-ridden with performance tunes, hence the need for gauges.
farmingdad
ky
Posted: 07/14/21 09:30pm Link  |  Quote  |  Print  |  Notify Moderator
I have a hydraulic belt driven radiator fan. How can it be adjusted to kick on a little quicker.
Bikeboy57
Inverness, FL
Posted: 07/18/21 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
Ivylog told you what to do. Instead you want to put a thermostat in it different from what Cummins provided or alter the fan setup different than what Spartan specified. I dont get it.
Richard and Rhonda
1999 Newell
Subaru Outback toad
Ivylog
Posted: 07/19/21 06:44am Link  |  Quote  |  Print  |  Notify Moderator
Hit the down arrow on the Alison shift pad a couple times.
wolfe10
Posted: 07/19/21 07:48am Link  |  Quote  |  Print  |  Notify Moderator
If your engine is OE, not "modified", you do not need a EGT gauge. Cummins took care of insuring that it could not over-temp.
Absolutely if you have modified it, adding more fuel, you need one.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
