RV.Net Open Roads Forum: Tech Issues: Tire engineering question.
 > Tire engineering question.
jjrbus
FT Myers FL
Posted: 07/14/21 05:26am Link  |  Quote  |  Print  |  Notify Moderator
So I go and get rig weighted and inflate rear tires to 10% over psi suggested in load and inflation tables.
Driving along and whats that BOOM noise? Got a blow out on the rear. In a miles long construction zone with no exits or place to pull over. Now one tire on one side is way overloaded, on my RV would be about 30% overload.
Question would be how far can I drive on the remaining tire before destroying it or needing to replace?
QCMan
Independent Republic of Horry
Posted: 07/14/21 05:48am Link  |  Quote  |  Print  |  Notify Moderator
Until it blows up and joins its partner.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Monterey, California
Posted: 07/14/21 07:33am Link  |  Quote  |  Print  |  Notify Moderator
Yes but replace the unblown tire as soon as you can.
n0arp
FT
Posted: 07/14/21 07:37am Link  |  Quote  |  Print  |  Notify Moderator
I have no specific answers to this, but an anecdotal one. We limped a friend's MH about 25mi to town on just an inner once. That inner was certainly very overloaded, and is still in service with a repaired outer several months later.
2021 Ram 5500 Limited 84CA Cummins 4x4 w/ flatbed
2020 Jeep Wrangler Unlimited Rubicon 2.0T (follow or TC toad)
2015 Keystone Alpine 3730FB 2925W/22.8kWh, 30K multi-split
2016 Arctic Fox 1140 WB 1800W/11.4kWh
JKJavelin
Milwaukee, WI
Posted: 07/14/21 09:40am Link  |  Quote  |  Print  |  Notify Moderator
You will find all kinds of tire engineers right here on this forum.
To answer your question (as a non-engineer), I would replace it ASAP, I wouldn't trust it.
JK
2018 Ram 3500 Laramie Cummins 6.7
2016 Open Range RF316RLS
Titan Disc Brakes
Trailair pinbox
Morryde SRE-4000 w/ wetbolt kit
Demco Hijacker Autoslide 18k
570 watts of Solar
2017- 21 Nights
2018- 75 Nights
2019- 138 Nights
2020- 72 Nights
2021- 110 Nights
Tal/IL
Central Illinois
Posted: 07/14/21 09:46am Link  |  Quote  |  Print  |  Notify Moderator
Your tire failure may have been totally unrelated to air pressure. Still, I am curious: how did "10% over psi suggested in load and inflation tables" compare to sidewall max pressure?
35 miles from Normal, IL. As close to normal as I'll ever be.
2006 Country Coach Inspire Genoa 40ft
Old-Biscuit
Verde Valley
Posted: 07/14/21 10:03am Link  |  Quote  |  Print  |  Notify Moderator
One tire blow out on a Dual means the other tire was instantly overloaded......damage is done and increases with drive time
No place to safely pull off....then you drive on it until you can safely pull over EVEN if it blows and your on the rim.
Gonna need 2 new tires regardless.
US NAVY------USS Decatur DDG31
MNRon
Tennessee
Posted: 07/14/21 10:17am Link  |  Quote  |  Print  |  Notify Moderator
What Old Biscuit said
Ron & Pat
2013 Silverado 3500 Duramax SRW
2019 VanLeigh Vilano 320 GK
n0arp
FT
Posted: 07/14/21 10:35am Link  |  Quote  |  Print  |  Notify Moderator
I tend to agree, I'd personally replace both tires afterwards for peace of mind.
jjrbus
FT Myers FL
Posted: 07/14/21 10:52am Link  |  Quote  |  Print  |  Notify Moderator
Tal/IL wrote:
I DID NOT HAVE A TIRE FAILURE. I keep getting told to run tires at much higher pressure in case I get a blow out, makes no sense.
In my mini Toyota sidewall max psi is 65, load and inflation table load range D tire calls for 39 psi, I run 43 and use TPMS.
