jjrbus
FT Myers FL
So I go and get rig weighted and inflate rear tires to 10% over psi suggested in load and inflation tables.
Driving along and whats that BOOM noise? Got a blow out on the rear. In a miles long construction zone with no exits or place to pull over. Now one tire on one side is way overloaded, on my RV would be about 30% overload.
Question would be how far can I drive on the remaining tire before destroying it or needing to replace?
QCMan
Independent Republic of Horry
Until it blows up and joins its partner.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Owens River area
Yes but replace the unblown tire as soon as you can.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
n0arp
FT
I have no specific answers to this, but an anecdotal one. We limped a friend's MH about 25mi to town on just an inner once. That inner was certainly very overloaded, and is still in service with a repaired outer several months later.
JKJavelin
Milwaukee, WI
You will find all kinds of tire engineers right here on this forum.
To answer your question (as a non-engineer), I would replace it ASAP, I wouldn't trust it.
JK
2018 Ram 3500 Laramie Cummins 6.7
2016 Open Range RF316RLS
Titan Disc Brakes
Trailair pinbox
Morryde SRE-4000 w/ wetbolt kit
Demco Autoslide
570 watts of Solar
2017- 21 Nights
2018- 75 Nights
2019- 138 Nights
2020- 72 Nights
2021- 122 Nights
2022- 85 Nights
Tal/IL
Central Illinois
jjrbus wrote: So I go and get rig weighted and inflate rear tires to 10% over psi suggested in load and inflation tables.
Your tire failure may have been totally unrelated to air pressure. Still, I am curious: how did "10% over psi suggested in load and inflation tables" compare to sidewall max pressure?
35 miles from Normal, IL. As close to normal as I'll ever be.
2006 Country Coach Inspire Genoa 40ft
Old-Biscuit
Verde Valley
One tire blow out on a Dual means the other tire was instantly overloaded......damage is done and increases with drive time
No place to safely pull off....then you drive on it until you can safely pull over EVEN if it blows and your on the rim.
Gonna need 2 new tires regardless.
US NAVY------USS Decatur DDG31
MNRon
Tennessee
What Old Biscuit said
Ron & Pat
2022 F350 Lariat CCSB SRW Diesel
2019 VanLeigh Vilano 320 GK
n0arp
FT
I tend to agree, I'd personally replace both tires afterwards for peace of mind.
jjrbus
FT Myers FL
Tal/IL wrote: jjrbus wrote: So I go and get rig weighted and inflate rear tires to 10% over psi suggested in load and inflation tables.
I DID NOT HAVE A TIRE FAILURE. I keep getting told to run tires at much higher pressure in case I get a blow out, makes no sense.
In my mini Toyota sidewall max psi is 65, load and inflation table load range D tire calls for 39 psi, I run 43 and use TPMS.
