RV.Net Open Roads Forum: Tech Issues: Max Air Vent Cover Maintenance
 > Max Air Vent Cover Maintenance
schlep1967
Harrisburg, PA
Posted: 07/14/21 07:34am Link  |  Quote  |  Print  |  Notify Moderator
Well sort of...
Our 2009 5th wheel has a Max Air cover over one roof/fan vent next to the shower. I realized last week that even though the cover has caulking around it, the back side is not sealed as it is in fact a screened vent. This made me think that I have never had the cover off to inspect the actual seal around the vent. So last night I got on the roof to check things out.
What I found was that having the front and sides of the max air cover sealed basically holds any water that may get in there inside where it will sit until it evaporates. OR it will find any entrance around the actual fan that has not had any caulking replaced in the ten years I've had the camper.
So this is a heads up to those with Max Air type of covers. Remove the cover every few years and check the caulking that actually seals the vent/fan to the roof.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
EMD360
Arvada, CO
Posted: 07/14/21 07:55am Link  |  Quote  |  Print  |  Notify Moderator
I use eternabond tape. It lasts at least a decade. Probably longer.
2018 Minnie Winnie 25b New to us 3/2021
Former Rental Owners Club #137
2003 Itasca Spirit 22e 2009-2021
schlep1967
Harrisburg, PA
Posted: 07/14/21 09:14am Link  |  Quote  |  Print  |  Notify Moderator
I didn't have any tape on hand. I did have a tube of Lap Sealant handy.
This post is more of a reminder to revisit the SEAL under the covers than a recommendation of what to seal it with.
Monterey, California
Posted: 07/14/21 11:45am Link  |  Quote  |  Print  |  Notify Moderator
Good tip. Thank you.
hornet28
Muskegon Mi.
Posted: 07/14/21 02:27pm Link  |  Quote  |  Print  |  Notify Moderator
The Max Air cover isn't meant to be caulked/sealed.
Maxx Air vent cover installation by RV Education 101 - YouTube
Ron3rd
Upland, CA USA
Posted: 07/14/21 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
That's why I like the Maxx Air II that has the quick release pins so you can easily check the condition of the vent base caulk. The vent cover itself is never caulked as noted above.
2016 6.7 CTD 2500 BIG HORN MEGA CAB
2013 Forest River 3001W Windjammer
Equilizer Hitch
Honda EU2000
schlep1967
Harrisburg, PA
Posted: 07/15/21 05:28am Link  |  Quote  |  Print  |  Notify Moderator
My Maxx Air was installed by Open Range. They used Butyl tape and then self leveling caulk. And they broke the plastic at every one of the corners when the tightened down the screws. We don't plan on having this trailer much longer. At 12 years old it has bounced down the road enough times I don't want to go into retirement with it. Hopefully the new one will get the quick connect Maxx Air II's.
Dusty R
Charlotte Michigan 48813
Posted: 07/15/21 06:40am Link  |  Quote  |  Print  |  Notify Moderator
I put a MaxxAir 1200T on our MH. That was the one that had about an 145* arc, which would not allow rain in.
We traded that MH for a new one, and I went to get a new MaxxAir 1200T to put on the new MH and found that they were no longer made. Wish I could find a good used one.
hornet28
Muskegon Mi.
Posted: 07/15/21 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
I sure wouldn't have them do any work on my unit if that's their level of competence
LarryJM
NoVa
Posted: 07/15/21 11:51pm Link  |  Quote  |  Print  |  Notify Moderator
If I'm understanding your post the folks at Open Range were idiots since the Max Air covers an NOT ATTACHED DIRECTLY to the roof. you attach brackets to the actual vertical part of the vent flange and then the Max Air cover is attached to that. The Max Air cover never actually touches the roof ... it sits about 1/4" off the roof so it's impossible for water to get trapped between the cover and the actual roof vent.
Larry
RAINKAP INSTALL////ETERNABOND INSTALL
