RV.Net Open Roads Forum: Class C Motorhomes: buying an rv
 > buying an rv
josianna
British Columbia
Posted: 07/14/21 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
hi I have heard of a 2003 Bigfoot 30mh27ds for sale for 54000 and it has 61, 000 original miles on it. the seller claims it belonged to a rather old woman who no longer camps. Any comments? Price what to look for and any other suggestions you might have please.
Quartzsite, AZ
Posted: 07/14/21 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
Get a pro inspection of the house and chassis. Not using any motor vehicle isn’t necessarily good. Be prepared to change all fluids and tires if you buy it. I’ll bet their are no maintenance records cuzz it wasn’t used.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
gbopp
The Keystone State
Posted: 07/14/21 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
I can't comment on the Bigfoot. When you decide on a particular RV (or a few) hire a mobile RV Tech to do an inspection.
It will be money well spent.
josianna
British Columbia
Posted: 07/14/21 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
thank you good info
Walaby
Georgia
Posted: 07/14/21 05:26pm Link  |  Quote  |  Print  |  Notify Moderator
Just be mindful that the demand for RV's is high and people are asking (and getting) premium prices for their used rigs. It will be hard to assess a good price for a used RV because many buyers know that if you don't buy it, there will be others behind you that will. So, harder to negotiate prices. And harder to determine what fair market value is as well.
You can try using things like NADA and look at their used values for any RV you are looking at. Just be mindful that their values are most assuredly pre-covid, and RV prices are in territory that really no one can accurately evaluate. But, it will still give you an idea if the seller is insane, or just a little crazy in their valuation.
I read your other post as well about getting into RVIng for first time, and maybe doing some full time RVing as you look for a new house. I don't know how the RV rental market is in Canada, but you might consider renting as you work the bugs out of your RVing experience. Renting an RV can give you some time to figure out what you like about the particular rig you are renting, but more importantly, what you DON'T like. So, when you get ready to buy, you know what's important to you and what you're willing to compromise on.
Obviously, renting an RV is "sunk money" that you won't get back, but it could better prepare you for this big step. Plus, give you some insight and thoughts about what to look for problem wise in RV's. The suggestion about hiring a mobile tech to evaluate/do the PDI is a good one too.
Just food for thought.
Mike
Im Mike Willoughby, and I approve this message.
2017 Ram 3500 CTD (aka FRAM)
2019 GrandDesign Reflection 367BHS
josianna
British Columbia
Posted: 07/14/21 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
thank you. good idea on learning to evaluate the price of an rv.
diplomatdon
Blaine, WA
Posted: 07/14/21 11:03pm Link  |  Quote  |  Print  |  Notify Moderator
Bigfoot was one of the best built Class C motorhomes in that era. Better built than most today. That price is Cdn $ I presume and the mileage Kilometers? The price is not out of line if my assumptions are correct. Have it inspected and deal accordingly. Bigfoots really hold their value. Good luck, Don
IB853347201
Eastern Ontario
Posted: 07/15/21 05:27am Link  |  Quote  |  Print  |  Notify Moderator
For a 2003 27 ft Class C $54,000 seems very high.
Should be selling for much less. $25,000 to $30,000, tops!
Check out AutoTrader.ca
Lots of used 2001 - 2005 Class C RV's in the $25 - 30,000 range
* This post was edited 07/15/21 05:37am by IB853347201 *
2010 Suncruiser
theoldwizard1
SE MI
Posted: 07/15/21 06:50am Link  |  Quote  |  Print  |  Notify Moderator
If the roof has not been properly maintained, it MIGHT need a complete roof rebuild. $$$$. A good inspection would reveal this.
If it has been leaking, the floor may have rotted. At that point RUN AWAY !
valhalla360
No paticular place.
Posted: 07/15/21 10:37am Link  |  Quote  |  Print  |  Notify Moderator
If you have a full size SUV or pickup, a travel trailer may be a good alternative for significantly less money. As a single person, a 15-18ft trailer should be workable and you don't need a monster 1 ton dually to pull it.
On of the issues with a motorhome is you either need to pull a car behind it or you have to break camp every time you want to run up to the store. With a trailer, you have a built in vehicle to run around with.
If you go this route: Do check the ratings...in particular the payload assuming 15% of the trailer sits on the hitch and counts against the payload (Payload often runs out before you reach the tow rating limit).
As others have said, the biggest likely issue is water damage from leaks. It would be well worth it to pay an RV tech a couple hundred to go over it looking for leaks and making sure everything is functional.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
 > buying an rv
