RV.Net Open Roads Forum: Tech Issues: Honda Gen EU2000i and EU2200i Companion
 > Honda Gen EU2000i and EU2200i Companion
Slick Rick
Eastern Shore of Virginia
Posted: 07/14/21 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
Can I mate my 5 year old EU2000i with a new EU2200i Companion (not purchased yet)? My gen has the parallel connectors. Or do I need to find a EU2000i Companion? Can't find a new one yet, maybe gotta look used if the new companion won't work.
TIA
2015 F350 Lariat CC PSD 4x4 SRW
2015 Lance 865 Truck Camper
bgum
South Louisiana
Posted: 07/14/21 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
Yes there should be a list online that shows what 2000 models it will mate with.
The EU2200i are only compatible with EU2000i or EU2000i Companion models within a specific serial number range:
EAAJ-2017305 through EAAJ-9999999
EACT-1000001 through EACT-9999999
Connecting an EU2200i with an EU2000i or EU2000i Companion that is not within the compatible serial range above may cause a low voltage output, which can damage tools and appliances powered by the generators. Units outside the compatible serial number range should only be paralleled with another EU2000i
* This post was edited 07/14/21 06:45pm by bgum *
jdc1
Rescue, Ca
Posted: 07/14/21 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
Honda says no...but you can. Many have and do do it.
Seon
Lake Camanche, CA
Posted: 07/15/21 07:24am Link  |  Quote  |  Print  |  Notify Moderator
Not only to those two but as an example can also parallel connect 2000 watts to 3500 watts generators.
https://www.desertcart.co/products/41323........ects-2-000-watt-to-3-500-watt-generators
ReneeG
Meridian, Idaho
Posted: 07/15/21 01:36pm Link  |  Quote  |  Print  |  Notify Moderator
Interesting. That's the knowledge we were going off of, from Honda.
Probably negates any warranty on the 2200.
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
jaycocreek
Idaho
Posted: 07/16/21 08:36am Link  |  Quote  |  Print  |  Notify Moderator
Westinghouse has a kit to hookup two of there inverter generators that also works with the Honda generator..I can parallel my Westinghouse 2200 and my Honda 2000 with it..
YouTube video showing
ReneeG
Meridian, Idaho
Posted: 07/16/21 08:58am Link  |  Quote  |  Print  |  Notify Moderator
Per Honda:
EU2200i and EU2000i Parallel Operation
Connecting an EU2200i with an EU2000i or EU2000i Companion that is not within the compatible serial range above may cause a low voltage output, which can damage tools and appliances powered by the generators. Units outside the compatible serial number range should only be paralleled with another EU2000i.
Here's the link to that information
LScamper
Los Alamos NM
Posted: 07/16/21 11:30am Link  |  Quote  |  Print  |  Notify Moderator
May cause damage to things plugged in. Does not say it will damage the generator. Am I hearing that correctly? Check the voltage and may be OK?
Lou
2oldman
NM
Posted: 07/19/21 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
Done it myself. In fact, mated a 2200 with 2 2000s. Now, mating 2 2200s with a 1000.
ReneeG
Meridian, Idaho
Posted: 07/20/21 06:55am Link  |  Quote  |  Print  |  Notify Moderator
That's what I read.
