RV.Net Open Roads Forum: Tech Issues: Filling dually tires
 > Filling dually tires
SHRED
California
Posted: 07/15/21 10:19am Link  |  Quote  |  Print  |  Notify Moderator
I'd have solid valve extensions installed but I've read they are incompatible with the built in TPMS system on our 2021 E-450 class c.
I'm looking for a way to add air without needing to remove the wheel covers.
I bought an extension chuck but it still interferes with the cover.
Are there any that are angled better that would work without having to remove the covers?
2021 27' Lazy Daze mid bath
madjack60
littleton
Posted: 07/15/21 10:35am Link  |  Quote  |  Print  |  Notify Moderator
I bought a long chuck from amazon and a tire guage to match, they work fine. I don't have extensions on my duals
madjack60
littleton
Posted: 07/15/21 10:36am Link  |  Quote  |  Print  |  Notify Moderator
They were both angled, takes a little practice
SHRED
California
Posted: 07/15/21 10:44am Link  |  Quote  |  Print  |  Notify Moderator
I have tried and tried.
This angle does not work.
DrewE
Vermont
Posted: 07/15/21 10:46am Link  |  Quote  |  Print  |  Notify Moderator
I find the chucks with the inner wheel end straight on rather than angled are more convenient than those with both angled. I suppose that may well vary with the specific wheel design you have. Either one can work, but might require more or less fiddling around to get a good seal, possibly including reaching around between the tires with the other hand to guide the chuck and valve stem into alignment.
Air-through valve covers are a big help; besides not having to unscrew the valve cover (and you really ought to use some sort of a valve cover), they effectively extend the stem a little bit and that little bit helps. I have Alligator brand ones and they seem very well made.
SHRED
California
Posted: 07/15/21 11:05am Link  |  Quote  |  Print  |  Notify Moderator
Thanks.
They do have air thru valve cover/caps.
IAMICHABOD
Sunny So Cal
Posted: 07/15/21 11:19am Link  |  Quote  |  Print  |  Notify Moderator
According to the Spec sheet
it says this "(TPMS; excludes spare; DRW)"
Former El Monte RV Rental
Buying A Rental Class C
Posted: 07/15/21 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
I used to use a dual angled chuck like pictured above and the pipe extension for the lug nut cover wrench.. Till I got Dually valves put in.
I know of NOT TPMS system that the Dually valves would be incompatable with
There are basically 3 types of TPMS systems
One is a sensor inside the rim, mounted in a different hole than the Valve stem
one screws on the end of the stem
And one uses the ABS sensors to sense a wheel turning faster than it should.
Dually Valves should not have a problem with any of these.
scbwr
North Ridgeville, OH
Posted: 07/16/21 06:58am Link  |  Quote  |  Print  |  Notify Moderator
Dually valve stem kits
Get dually one piece valve stems and you will solve your problem. I was having several problems with the rear axle tire stems on my Bay Star, so I broke down and bought the dually kit and had one piece valve stems installed on both inner and outer rear axle tires. Now, maintaining air pressure and using TPMS sensors is easy. The dually stems are a bit pricey, but well worth it!!
2012 Newmar Bay Star 3302
Blue Ox Avail
BrakeBuddy Advantage
2015 Malibu
"Get busy living, or get busy dying."
Andy Dufresne, The Shawshank Redemption
bucky
Raleigh metro
Posted: 07/17/21 04:53am Link  |  Quote  |  Print  |  Notify Moderator
I have never seen the above kits before. Interesting solution to an age old problem. I'm getting too old to be humping heavy wheel and tire combos around. Thanks for the link. Certain tire machines may have issues with these, you may have to install them after the tire is on the rim to avoid shooting them into the wall or the installer.
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
