RV.Net Open Roads Forum: Tech Issues: Does closing most A/C vents create back-pressure?
 > Does closing most A/C vents create back-pressure?
profdant139
Posted: 07/15/21 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
We have a very small trailer and a fairly big a/c unit -- over 13,000 BTUs, I think. (That's the way the trailer was equipped.) It gets cold in a hurry in there, which I personally like. But DW does not like it when the cold air blows on her, which I understand.
Aside from turning down the fan and turning up the thermostat, we have also tried shutting some of the various vents that are built in to the a/c unit.
My question is a simple one: if we close almost all of the vents, does that create back-pressure within the a/c unit? And if so, is that harmful to the unit?
Thanks in advance for your wisdom!
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
stripit
Prescott
Posted: 07/15/21 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
Someone may know more than I do, but we used to do that exact same thing in our travel trailer, never had any problems. I would think maybe with less air flow it might ice up in some conditions, but never had that issue.
Stacey Frank
2016 Tiffin Allegro Bus 40AP
2019 Tesla Model X
2015 Cadillac SRX we Tow
1991 Avanti Convertible
sch911
Rochester Hills, MI
Posted: 07/15/21 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
The reduced airflow over the evaporator can cause ice to form, and lead to a possible freeze up which is not good for the compressor. So you'd have to try it out and see if that happens. As far as the blower fan is concerned that offers no issue. Airflow CFM is directly proportional to current draw. Less airflow = less fan current.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
Dick_B
Palos Heights, IL USA
Posted: 07/15/21 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
Just slightly off topic but too large an A/C can cool off the air without reducing the humidity which leaves one cold and clammy.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
time2roll
Posted: 07/15/21 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
I would be more inclined to put a baffle up to redirect the cold air away from her and toward you. Same as you do with the car vents.
675w Solar pictures back up
Old-Biscuit
Verde Valley
Posted: 07/15/21 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
They do make adjustable roof ceiling vents.....
13.5K btu A/C Unit is standard size
15K is the large size
Close off the vent you want....
Unlike furnace---less duct/vents will not cause A/C harm
**Might cause Evap Coil to Ice up which is easy to correct
US NAVY------USS Decatur DDG31
pianotuna
Regina, SK, Canada
Posted: 07/15/21 11:20pm Link  |  Quote  |  Print  |  Notify Moderator
Which can be solved by running an electric heater.
Regards, Don
Posted: 07/16/21 04:35am Link  |  Quote  |  Print  |  Notify Moderator
For a free standing fan.. Likely true
For the blower in the A/C..... Complex
Closing most of the vents WILL cause back pressure but how much?
Back pressure means less air will flow (Hence the ice up comments)
But it also means the blower is working harder against the pressure
This INCREASES the current draw.
valhalla360
No paticular place.
Posted: 07/16/21 06:14am Link  |  Quote  |  Print  |  Notify Moderator
Did you try switching the fan setting to low (most units have a hi or low option).
In S. Cal, it's unlikely you will run into icing as as that's generally an issue with high humidity. The moisture condenses on the fins (like the outside of a glass of ice water) but the fins are below freezing, so it then freezes...gradually it builds up until air can't flow between the fins and you get no air flow. Higher airflow helps avoid that issue. If you close off the vents, it creates a similar issue. If it does happen, just switch to fan only (no air/con) for 10-15min and it will quickly melt the ice.
Another question, do you actually have a ducted air/con? That would be unusual for a really small trailer. Usually the cold air just blows out of the main unit because you don't have to worry about getting cold air to a separate bedroom.
- If you do have a ducted unit, closing off just the vent blowing on your wife, shouldn't cause much issue.
- If it's blowing out of the main unit, you are probably cutting off 50% of the airflow if you close one side. That would be a bit of an issue if you are somewhere humid.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
larry cad
ohio
Posted: 07/16/21 06:15am Link  |  Quote  |  Print  |  Notify Moderator
Come on Dave, you know better than that! Work is defined in physics as a force causing the movement (displacement) of an object. If you don't "move" the air, there is no work done. Less movement means less amps from the blower motor.
Did you ever put your hand over the end of a vacuum cleaner hose? The motor speeds up due to less work. Also draws less amps. Get an clamp on amp meter and check me out. You can totally block off the vents and the motor will speed up due to almost no load on the motor.
Our Travel Blog
