RV.Net Open Roads Forum: Tech Issues: power issue
 > power issue
car54Don
west coast north of the 49th
Posted: 07/16/21 11:04pm Link  |  Quote  |  Print  |  Notify Moderator
'07,Itasca Sunrise. Returned home from camping last Sunday, everything was working good.
At home plugged into house to run fridge only, as going again soon. Fridge has been working fine for 5 days.
!! Today fridge reads no AC. Tried to restart on AC no go.
Switched to propane. Running fine on propane.
I pushed test on ground fault. !! Now it will not reset, no power at outlets. Microwave no power.
any help? thx
*update* ! got it fixed. replaced 2 GFIs.
* This post was edited 07/18/21 06:17pm by car54Don *
gbopp
The Keystone State
Posted: 07/17/21 04:36am Link  |  Quote  |  Print  |  Notify Moderator
Did you check the power at the outlet where you're plugged into the house?
Make sure you have power to the RV before you start diagnosing the problem. I don't think a GFCI will reset unless it has power.
larry cad
ohio
Posted: 07/17/21 04:57am Link  |  Quote  |  Print  |  Notify Moderator
any help? thx
Pushing test on the GFCI will trip the GFCI. The reset button is typically difficult to push. Push it harder. If it truly won't reset, you may have a defective GFCI, or there is truly a ground fault.
Our Travel Blog
enblethen
Moses Lake, WA
Posted: 07/17/21 06:30am Link  |  Quote  |  Print  |  Notify Moderator
You have lost 120 volts to the rig.
Reset circuit breakers in the rig. Turn off all breakers applying light pressure toward off. Then turn on main breaker if equipped, followed by each branch breaker one at a time.
GFCI receptacles will not reset without having 120 volts present.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
wildtoad
Blythewood, SC
Posted: 07/17/21 06:57am Link  |  Quote  |  Print  |  Notify Moderator
As above make sure socket you’re plugged into to
Make sure you have power there.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
jdc1
Rescue, Ca
Posted: 07/17/21 09:00am Link  |  Quote  |  Print  |  Notify Moderator
Follow all the above advice, but first unplug everything in the trailer. Also, check the source of the trailer power (your house power)
opnspaces
San Diego Ca
Posted: 07/17/21 10:52am Link  |  Quote  |  Print  |  Notify Moderator
As above check the power source. A GFCI will not reset if there is no power to it. It also will not reset if there is a true short or if it's faulty. But if there is no AC in the entire rig then your problem is further upstream from the GFCI. Check at the main breaker in the RV. Check for damage to the shore power cord. Check for power where the cord is plugged into the house.
* This post was edited 07/21/21 09:14am by opnspaces *
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
enblethen
Moses Lake, WA
Posted: 07/17/21 10:58am Link  |  Quote  |  Print  |  Notify Moderator
Using an adapter to plug into shore power, it could be bad.
bguy
The Rock
Posted: 07/17/21 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
Remove any plugs in your outside outlet. It's also possible the outlet itself may have got water in it while something was plugged in. May even dry out and the problem go away.
2011 Ram 1500 Quad Cab, 4x4, 3.55, HEMI
2009 TL-32BHS Trail-Lite by R-Vision
3 tons
NV.
Posted: 07/17/21 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
any help? thx
Not all of your home circuits are fussy GFI protected…Find a circuit that is not GFI protected and using an extension cord, connect to the RV and see what happens…
3 tons
 > power issue
