RV.Net Open Roads Forum: Beginning RVing: Heated hose
 > Heated hose
SDcampowneroperator
South Dakota
Posted: 07/18/21 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
Lwiddis wrote:
Leaving any hose hooked up when freezing temperatures are expected isn’t a wise idea. Fill the tank and use the pump.
X2!
Posted: 07/19/21 05:02am Link  |  Quote  |  Print  |  Notify Moderator
Swiddis and SDcampowner
That's how I ended up doing it. Fill on board, disconnect and drain.
No problems.
smarty
new mexico
Posted: 07/19/21 09:09am Link  |  Quote  |  Print  |  Notify Moderator
If you are camping at xmas, and just for a weekend, skip the water line. Especially if it is going to be near zero
Posted: 07/19/21 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
Oh on a trailer... (In case my sig file was not a hint I was in a motor home)
A couple of 5 gallon jerry cans INSIDE may work too, plus you can refill as needed.
parker.rowe
Delaware
Posted: 07/20/21 10:51am Link  |  Quote  |  Print  |  Notify Moderator
pitch wrote:
Many parks will ask you to fill your tanks and disconnect city water if they expect a freeze.
This is what they do around here at the state parks, so a heated hose wouldn't help.
If its going to be cold enough, then make everyone unhook at x time and turn off the water.
We just make sure the tank is full and have no problems, but we have never had to deal with temps where they have the water off all day.
Latest we camp is for Thanksgiving.
OP, might help to call where you plan to camp for Christmas and see if they turn the water off. Could save you some money on that hose!
2015 Starcraft TravelStar 239TBS 6500 GVWR
1997 GMC Suburban K2500 7.4 Vortec/4.10
1977 Kawasaki KZ1000
wapiticountry
Mountain West
Posted: 07/20/21 10:57am Link  |  Quote  |  Print  |  Notify Moderator
Heat tape is meant for use on metal pipes. Those pipes conduct heat and prevent freezing. Plastic pipe and hose materials do not conduct heat and may actually be damaged by heat tape.
 > Heated hose
