RV.Net Open Roads Forum: Tech Issues: Shower hose fittings problem
 > Shower hose fittings problem
kejones62
Oregon
Posted: 07/19/21 11:19am Link  |  Quote  |  Print  |  Notify Moderator
I have a Jayco travel trailer. I needed to replace the shower hose, so I bought one off of Amazon. I can screw the 'head' end of the hose onto the head, no problem. However when I go to screw the other end onto the faucet diverter, it goes on maybe a half turn and sticks. At this point the internal mating surfaces are not pressed together - the hose rattles loosely in the nut - so it is not a watertight seal. I've played with this for hours, although the fittings look the same, and the thread pitch is the same, the fittings won't go together. Has anyone had this issue before? Is there some adapter I need? I thought these things were all 'universal'.
BTW, this is the hose I bought. Cheap enough to just get a different one, but I don't know if that will help. Blissland Shower Hose
agesilaus
North Florida
Posted: 07/19/21 11:37am Link  |  Quote  |  Print  |  Notify Moderator
Odd every shower fitting I've seen is 1/2 inch pipe thread, 1/2 NPT.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
joelc
Cedar Point, NC
Posted: 07/19/21 11:57am Link  |  Quote  |  Print  |  Notify Moderator
Go to a hardware store and bring your head (shower head, too). Let them take a look so you can purchase the right one.
wopachop
Who run bartertown
Posted: 07/19/21 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
Both ends appear to be the same size.
Does the shower head screw into the other side?
It it only goes 1/2 turn it sounds like a difference in threads or a bad thread job.
kejones62
Oregon
Posted: 07/19/21 01:14pm Link  |  Quote  |  Print  |  Notify Moderator
if I grab a 1/2 NPT male, I can screw it into either end of the hose. However on the end that goes into the diverter, I can only get it a few turns before it starts to tighten. The threads are definitely 1/2"-14, but maybe the taper is off? I can actually get it more than 1/2 turn onto the diverter - that was a mistake - but I can't get it tight enough to mate the washers. The thread get tight before the washers mate.
DrewE
Vermont
Posted: 07/19/21 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
Can you maybe put in more washers or a thicker washer to take up the extra space?
wopachop
Who run bartertown
Posted: 07/19/21 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
The diverter must be a metric thread?
If you have the old hose, see if the Male shower head screws into the old hose on the diverter side.
wildtoad
Blythewood, SC
Posted: 07/19/21 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
Have you tried putting some Teflon tape on the diverted? Could the old hose have been put on skewed and corrupted the threads? All shower hoses have the same sized threads.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
kejones62
Oregon
Posted: 07/19/21 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
The diverter is original, and I'm sure it's not metric - it's 1/2-14.
I don't have the old hose anymore.
I can try stacking washers, but it's going to take 3/8 or 1/2 inch of them.
mobeewan
Hampton, Va
Posted: 07/19/21 02:29pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you are connecting the knurled fitting which appears to have deeper longer threads to the diverter and the hex nut fitting to the shower wand. Try swapping them.
