RV.Net Open Roads Forum: Tow Vehicles: 1/2 ton towing a 5th wheel
Search only in Tow Vehicles
 > 1/2 ton towing a 5th wheel
ShinerBock
LVTX
Posted: 07/21/21 07:10am Link  |  Quote  |  Print  |  Notify Moderator
FYI, the sticker on the door jamb is as useless as tits on a bull if you replaced your stock tires/rims with ones that have a lower rating. It also goes out the door if replaced any suspension components with a lift.
Case in point, my nephew replaced his stock rims and tires on his 3500 with 35x12.5x20 BFG T/A KO2's which has a max rating of 3,195 lbs. The 6,390 lb combined rating of the new tires had a lower rating than his stock axle rating of 7,000 lbs which effectively lowered his GAWR making the number on the door sticker worthless. It actually put him below the rear GAWR of my 2500 which is 6,500 lbs.
2014 Ram 2500 CTD
Highland Ridge Silverstar 378RBS
IdaD
Idaho
Posted: 07/21/21 08:50am Link  |  Quote  |  Print  |  Notify Moderator
I was careful with the weight rating on my aftermarket wheels to be sure I didn't de-rate my truck. As Shiner says, same goes with tires if you change the size or type.
My take on a half ton with a fifth wheel is you can do it with the right combo but there aren't too many options that will fit the bill in terms of the particular half ton or fifth wheel. That said, beef up the tires and supplement the suspension and you can probably cheat a little on your official payload rating. At the end of the day you'll probably be happier just upgrading to an HD truck, though.
2015 Cummins Ram 4wd CC/SB
noteven
Turtle Island
Posted: 07/21/21 09:18am Link  |  Quote  |  Print  |  Notify Moderator
I tookalook at the Ford 2019 towing guide.
There is a listing of maximum trailer weights the different vehicle series can be spec'd for. (can be not all are can be not all are can be not all are....)
F-150 can be spec'd for a tick more rear tow trailer max weight than 5th wheel coupled max weight.
That's kind of interesting.
Posted: 07/21/21 09:29am Link  |  Quote  |  Print  |  Notify Moderator
OP.
Tires wheels suspension is easy. Slap some good E load tires on any OE or similar quality rims. Suspension, you have multitudes of options.
Any 9.75 axle 150 is good for 5klbs so the afformentioned 2500lbs payload is about right and a practical limit iMO.
2017 Heartland Torque T29
blt2ski
Kirkland, Wa
Posted: 07/22/21 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
OP.
Grit generally good thoughts.
BUT some 15 series rigs like my new to me GM, it has a 10 bolt 8.5" RA. NOT the 12bolt 9.5" like my son's 05. I believe in GMs case, the 6 cyl get the smaller RP setup. The V8's the 9.5" setup.
Like ALL things great and small, one needs to look at actual parts to see if you have the X or Y version.
Im not recalling OP saying engine, probably did, I would swag small eco boost and NA V6 could have smaller axles vs the larger EB and 5.0 V8.
Marty
Check RV.Net Blogs at: blog.rv.net
LowRyter
OKC
Posted: 07/22/21 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
If you're within weight limits, it should work. Be prepared to get 5 mpg when towing. Keep it under 65.
John L
WW SL 2805 5th Wheel
2004.5 Chevy 2500HD Allison Duramax X Cab
Ducati 939 SS, Moto Guzzi V11 Sport, Moto Guzzi EV California and Suzuki 1200 Bandit
time2roll
Posted: 07/22/21 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
Even my old dog gets 8 mpg [emoticon]
675w Solar pictures back up
mooky stinks
Cicero,NY
Posted: 07/22/21 08:30pm Link  |  Quote  |  Print  |  Notify Moderator
You lose all credibility when you make a statement like that.
2020 F150 XL Screw 4x4 6.5”box
3.5 ecoboost Max tow HDPP
7850 GVW. 4800 RAWR
2565 payload
2020 Cougar 29RKS 5th wheel
mkirsch
Rochester, NY
Posted: 07/23/21 06:08am Link  |  Quote  |  Print  |  Notify Moderator
Sure you can buy stouter tires and jam sections of well casing between the frame and axle to keep the truck from squatting, but you may never get things to where you will be happy with the results.
It's a very expensive guess. The whole point of looking at things on paper is so you can get an idea of what you're in for BEFORE you spend the money. I'm glad these guys who are just telling you to go for it and prop up the truck have infinite money and can just keep throwing cash at the problem, but most people don't. Not everyone is made of money. Some of us have one shot to get this right.
Right now, 1660 payload vs. 1375 EMPTY pin weight, it's not looking good. I don't consider GVWR a stone wall not to be breached, but F150s don't have the "hidden" payload capacity of an F250 or F350. It's more like 400lbs vs. 1000lbs+ on an F250 and a ton or more on an F350. You're going to be into your "hidden" capacity just towing the empty trailer home from the dealer with the family in the cab of the truck.
Groover
Pulaski, TN
Posted: 07/23/21 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
My daughter gets about 11mpg towing her 3 horse gooseneck with living quarters behind her 2013 Ecoboost at 70mph. You can figure about 85% of what a diesel would give under the same situation.
