RV.Net Open Roads Forum: Tow Vehicles: 1/2 ton towing a 5th wheel
Search only in Tow Vehicles
 > 1/2 ton towing a 5th wheel
Louiseintx
Posted: 07/20/21 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
Hello, thank you for all your responses. I am looking at a grand design Reflection fifth wheel-260RD. Specs are UVW 7,225. Hitch-1,325 GVWR-9,495. My F150 is rated at:GVWR-6,750 combined cargo wt and passengers-1,660 Rear GAWR 4,050 Front GAWR-3,300. Base weight-4,696 and it looks like from the Ford website, max conventional towing is 17,900 ( weight of truck and trailer together). I looked up what the hitch will weigh for my truck and it will be about 150 lbs. I don’t want to run out of payload and it looks like my payload is 2,054 (GVW minus curb weight) If I subtract the fifth wheel pin weight -1325 and the hitch weight-150, I’m left with 579 lbs for passengers plus whatever we put in the trailer. Which says to me, this won’t work. Would someone check my math and logic and let me know. I really appreciate all your help. So you know, we don’t currently have a fifth wheel so we cannot weigh it at this point but that would be the logical thing if we could.
blt2ski
Kirkland, Wa
Posted: 07/20/21 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
Trailer maxed out can be 2000-2500 lbs of hitch wieght. You payload is 1600. Not happening! You'll be way over Ford's warranty performance ratings.
Marty
2014 Chevy 1500 Dual cab 4x4
blt2ski
Kirkland, Wa
Posted: 07/20/21 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
By the way, based on your numbers, your truck wirghs from factory with options about 5100 lbs. Very few unicorns that wieght base brochure wt. I've owned a few. My GM 1500 is 5400, I have almost 8000 in spring capacity, 7200 gvwr. That's too big for mine. It's TOO BIG for yours.
Get a travel trailer.
MNRon
Tennessee
Posted: 07/20/21 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you’re contemplating starting the leapfrog game many of us have played…but a bigger trailer, necessitating a bigger truck…which then gives you ideas for a bigger trailer…repeat [emoticon]
Ron & Pat
2013 Silverado 3500 Duramax SRW
2019 VanLeigh Vilano 320 GK
MitchF150
Puyallup, WA
Posted: 07/20/21 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
Why are you looking at 'website ratings'? You have the truck, open the drivers door and look. That's what your truck weighs. Not the "curb weight" from the website...
That figure is for a zero option truck.
Anyway, work the numbers anyway you want... Ain't no way a #6750 GVWR truck is going to be comfortable towing a rig like what you want it to..
My F150 has #7700 GVWR and I would not want to tow that rig...
Good luck! Mitch
Trackrig
Spent the summer in Conconuly, Wa, MH now in Vanco
Posted: 07/20/21 10:19pm Link  |  Quote  |  Print  |  Notify Moderator
Sure it will pull it. If you go a couple hundred miles on flat ground, go for it.
The overall problem is it's a half ton. It may tow the load just fine, but the brakes won't last for long, the transmission isn't going to take a lot of miles, you don't have the truck weight to control the 5th in big wind gusts, etc, etc, etc.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
mooky stinks
Cicero,NY
Posted: 07/20/21 11:20pm Link  |  Quote  |  Print  |  Notify Moderator
My 5th wheel is 10000lbs gross. My F150 HDPP w/ max tow has an actual payload rating of 2565 and a rawr of 4800. At the scales with me, wife and dog with a full tank of fuel, it’s at 7980 which is 130 over my 7850 rating which I can live with. Rear axle is 4500.(300 under) Pin weight is 1850 with a total trailer weight of 9600. With your particular version of F150 you’ll be overloaded and I’d strongly advise against it. If it had the HD payload package it would be doable. That’s what makes or breaks this combo.
* This post was edited 07/20/21 11:34pm by mooky stinks *
2020 F150 XL Screw 4x4 6.5”box
3.5 ecoboost Max tow HDPP
7850 GVW. 4800 RAWR
2565 payload
2020 Cougar 29RKS 5th wheel
2112
Posted: 07/21/21 04:33am Link  |  Quote  |  Print  |  Notify Moderator
My FW UVW is 8100 and dry pin weight of 1170lbs. It weighs 9500lbs loaded, ready to camp and the pin weight is 1500lbs empty tanks.
My 2011 F150 GVWR is 7700 with 2080Lb payload. Your payload is 1660lbs. I'm 200lbs over the 4000Lb rear axle rating (5%). I also upgraded to LT tires.
It tows and stops great, no problem with hills. I have not towed in true mountains and probably never will. Everything is great UNTIL I fill the black and gray tanks. The tanks are forward of the FW axles, putting a lot of extra weight on my trucks rear axle, and I can tell the truck is not happy with it. My guess is with the tanks full I probably have at least 4600lbs on the rear axle.
From my experience and considering the information you provided, I give your idea a thumbs down. The published 1325lb pin weight is unloaded (dry). That will go up by 100's of lbs. You will run out of rear axle payload before you even get in the truck. Your truck can TOW this camper, it just can't CARRY it well.
* This post was last edited 07/21/21 05:07am by 2112 *   View edit history
2013 KZ Durango 2857
scbwr
North Ridgeville, OH
Posted: 07/21/21 06:04am Link  |  Quote  |  Print  |  Notify Moderator
Save yourself a lot of time and hassle and get a 3/4 or 1 ton truck. It's always better to be towing below the maximum specs. So, if you want to have a fifth wheel trailer, buy a truck that will give you a lot of options as you purchase a fifth wheel now, and later when you may want to upgrade or go with a larger fifth wheel.
2012 Newmar Bay Star 3302
Blue Ox Avail
BrakeBuddy Advantage
2015 Malibu
"Get busy living, or get busy dying."
Andy Dufresne, The Shawshank Redemption
valhalla360
No paticular place.
Posted: 07/21/21 06:07am Link  |  Quote  |  Print  |  Notify Moderator
Get the payload off the door jam, that will give you the real payload. The 4,696 is a stripped down version XL version. It could easily be 500lb higher.
But let's assume it's correct for the moment (in reality it's worse),
- 9,495 GVWR suggests 2000-2500 pin weight when ready to hit the road. 1,325 might be the pin weight when you take it home from the dealer (actually, it will likely be higher as they don't weigh the trailer as it rolls off the assembly line and it almost always comes out heavier) but once you add propane, water, clothes, food, etc... you are likely going to be much closer to 9,495 GVWR and most of that weight will sit in front of the axles increasing the pin weight.
- 6,750 minus 4,696 is about 2,054 but you also have 150lb hitch plus the wife plus anything else in the truck.
It's not even close...If you were over by 100lb, I might shrug and say it's not ideal but you are looking at being way over.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
