RV.Net Open Roads Forum: General RVing Issues: New 5er, fresh water
 > New 5er, fresh water
bsbeedub
Gateway to the West
Posted: 07/22/21 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
ReneeG wrote:
If you can use a funnel to put bleach in your tank, why can't you use a funnel to put fresh water in from a bucket?
The bleach is not just added with a funnel. As explained in my original post, the bleach is added to my fresh water hose with a funnel. The hose is then connected to a water spigot which is pressurized from my house and the water forces the bleach from the hose to the fresh tank.
It’s my understanding that just trying to pour water into the inlet on the trailer does not have sufficient pressure to flow into the tank. Many new trailers ( including mine) have no gravity fill inlet. That is why an external pump is needed to fill it if there is no city water connection.
Bob & Susan
Shelby the Beagle June 8, 2005 - Dec. 24, 2016
2018 Ram 3500 6.4 HEMI, long bed, 4.10’s
2021 Coachman Chaparral Lite 25 RE
2011 Gulfstream Ameri-Lite 23BW - retired
2003 Dodge Ram 1500 - retired
mobeewan
Hampton, Va
Posted: 07/23/21 02:51am Link  |  Quote  |  Print  |  Notify Moderator
Use the winterizing connection. Connect a hose to it. Drop the hose in a jug or bucket of water and pump it into the FW tank. When sanitizing add bleach to the jug or bucket. Make sure to set the valves in the wet bay to the proper positions.
ReneeG
Meridian, Idaho
Posted: 07/23/21 07:20am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the explanation.
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
bsbeedub
Gateway to the West
Posted: 07/23/21 07:40am Link  |  Quote  |  Print  |  Notify Moderator
The winterizing inlet bypasses the fresh tank as well. This assures that the anti freeze goes into the water lines only and does not pump excess anti freeze into the tank.
CA Traveler
The Western States
Posted: 07/23/21 09:21am Link  |  Quote  |  Print  |  Notify Moderator
The connection is on the suction side of the pump and the pump output does not go to the fresh water tank.
I add bleach, fill the water tank, then purge the water lines so that they get sanitized.
If you sanitize the hot water then drain it and the fresh water tank, refill and purge everything with fresh water.
Alternate: We use a reasonable amount of treated city/utility water in our travels and hence have very rarely sanitized.
2014 Grand Cherokee Overland
Bob
Posted: 07/23/21 10:05am Link  |  Quote  |  Print  |  Notify Moderator
If you’re not opposed to spending a few bucks for convenience, get a ballast bag and pump for a wakeboard boat.
Couple garden hose adapters will allow you to fill from any spigot with a hose connection and 12V fit lighter ballast pump will empty a 40-50 gal sack in about 2 minutes.
2017 Heartland Torque T29
Nodaker
North Dakota
Posted: 07/25/21 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
There should be a setting in the valves that will let the onboard water pump suck water from a bucket (or jug) into the system for winterizing. There then may be another setting that will suck the water into the fresh water tank - that setting would be used to draw water mixed with bleach into the tank for a full sanitizing of the system. That setting can be used to replenish the tank from a bucket.
I can't believe the tech you talked to in the original post didn't know how set the valves!
Nodaker
2010 Jayco Melbourne 29D
2011 Chev Colorado dinghy
kellem
Shenandoah valley,VA
Posted: 07/26/21 11:31am Link  |  Quote  |  Print  |  Notify Moderator
My sister recently bought a new trailer with these valves and has battled them all summer......looks like a cockpit on an airplane.
I imagine once procedure is learned things may simplify.
