Rbertalotto
Massachusetts
I'm parked at a friends house in Montana for a few days. I couldn't get my hot water heater to heat the water to the usual blistering degrees. I'd run the hot water to drain the tank down with fresh water entering and it wouldn't start. I checked voltages, connections, gas supply....everything was fine. Then I went into the bathroom and tuned on the COLD water and the water was very hot. Turns out the dark green, 100' hose from my friends house, laying in the hot sun, was heating the supply water to the hot water heater to just above the turn on thermostat setting. I was so relieved as I have 2600 miles to go to get home! This morning, upon turning on the hot water heater that wonderful, familiar "click" and "flame roar" was so welcomed! Hope this helps others that might find a similar situation.
RoyB
Dartmouth, MA
2018 RAM 2500 4X4 6.4L
2011 Forest River Grey Wolf Cherokee 19RR
420w Solar / Bogart SC2030 / Trimetrics
way2roll
Wilmington NC
And that is why it's not called a hot water heater.
Owens River area
"Turns out the dark green, 100' hose from my friends house, laying in the hot sun, was heating the supply water to the hot water heater to just above the turn on thermostat setting."
Would have been the last thing I thought about!
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
2012Coleman
Imagine that - a hot water heater that wont heat hot water....
Experience without good judgment is worthless; good judgment without experience is still good judgment!
2018 RAM 3500 Big Horn CTD
2018 Grand Design Reflection 303RLS
jdc1
Rescue, Ca
way2roll wrote: And that is why it's not called a hot water heater. ![wink [emoticon]](http://www.rv.net/sharedcontent/cfb/images/wink.gif)
Why would anyone need a "hot water heater"?
coolmom42
Middle Tennessee
That could be concerning, for sure. Glad you figured it out!
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
way2roll
Wilmington NC
jdc1 wrote: way2roll wrote: And that is why it's not called a hot water heater. ![wink [emoticon]](http://www.rv.net/sharedcontent/cfb/images/wink.gif)
Right.
CabinetmakerII
Idaho
My wife and I have had this discussion for years! Just cant get her to understand the "Water Heater" Is heating COLD water!
Cabinetmaker
2021 DRV 39 DBRS3
2017 F-450 4X4, Riece 24K Hitch
2011 F-450 4X4, Companion 18K Hitch, Air Bags (Retired)
2012 Cyclone 3800, 5th Airborne Kingpin (Retired)
2006 700 Arctic Cat ATV (X2)(Retired)
2014 Kawasaki Tyrex 4LE Side by Side
wildtoad
Blythewood, SC
Have a brother-in-law whom used to work for Lowe’s in the appliance department. He said anytime someone would ask to see their hot water heaters, he say something like… Sorry sir Lowe’s does not sell hot water heaters, but if you’d like to see an appliance that heats cold water they’re right this way under the water heater sign.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
wildtoad
Blythewood, SC
I see an opportunity for someone to come up with a set of valves similar to the wh bypass ones to allow an external source of preheated water (by solar) to feed the cold water side of the wh. That way you could use it when there is ample sun and warmth. A side benefit is a greater supply of hot water.
