RV.Net Open Roads Forum: General RVing Issues: Hot Water Heater Funny Issue
 > Hot Water Heater Funny Issue
Old-Biscuit
Verde Valley
Posted: 07/22/21 10:00pm Link  |  Quote  |  Print  |  Notify Moderator
Water heater only heats COLD water initially...after heated it reheats Hot Water cause 110*F temp is considered HOT water
Therefore it is perfectly acceptable to refer to it as a Hot Water Heater
Otherwise....get over yourselves.
US NAVY------USS Decatur DDG31
Boon Docker
Posted: 07/22/21 11:19pm Link  |  Quote  |  Print  |  Notify Moderator
We have a bunch of unemployed comedians and we can see why they are unemployed. [emoticon]
Lynnmor
Red Lion
Posted: 07/23/21 05:17am Link  |  Quote  |  Print  |  Notify Moderator
I would be more concerned with a dark green hose in the hot sun all day, that water must stink of plastic and is surely not a hose suitable for a drinking water system. If you must use an unsafe hose, at least run it off till fresh water flushes it out and then fill your tank and put the hose away.
CabinetmakerII
Idaho
Posted: 07/23/21 06:16am Link  |  Quote  |  Print  |  Notify Moderator
Perfectly acceptable to some... but not all!
Cabinetmaker
2021 DRV 39 DBRS3
2017 F-450 4X4, Riece 24K Hitch
2011 F-450 4X4, Companion 18K Hitch, Air Bags (Retired)
2012 Cyclone 3800, 5th Airborne Kingpin (Retired)
2006 700 Arctic Cat ATV (X2)(Retired)
2014 Kawasaki Tyrex 4LE Side by Side
Posted: 07/23/21 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
way2roll wrote:
And that is why it's not called a hot water heater. [emoticon]
Thank you for that w2r.. I needed a good laugh and I totally missed it this morning.. So Thanks
And yes you have a point.
