RV.Net Open Roads Forum: Tow Vehicles: Duramax Turbo adventure conclusion
Search only in Tow Vehicles
 > Duramax Turbo adventure conclusion
Near DVNP, California
Posted: 07/23/21 10:55am Link  |  Quote  |  Print  |  Notify Moderator
"The dealers refused to work on it without seeing the code for themselves."
Probably due to the manufacturer's rules.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
MNRon
Tennessee
Posted: 07/23/21 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
Grit Dog - I’m not going to bad mouth the garage that replaced the turbo (though wish we had tried the MAP sensor first) because I got that same advice from 3 dealership garages that looked at it over the couple years I was dealing with it. Sporatic problems are tough, especially when needing significant load to elicit. The good news here is that garage saved me significant $$$ from what the dealership garages quoted.
Since you’re in WA I will tell you that the guys that replaced the MAP sensor (directed solution from me after discussing it with my home garage) was H & H Diesel Repair in Fife, WA. I didn’t give them a real chance to diagnose etc because we were traveling and they were working me in to a full schedule. I can tell you they seemed to know what they were doing, worked with me to squeeze my repair in and tested it as best they could without dragging my 5er around. They concluded the new MAP sensor behaves a little different from the one they replaced. Couldn’t confirm that difference was related to my issue but made a good case it might be. Bottom line, I would go there again if in the area.
Ron & Pat
2013 Silverado 3500 Duramax SRW
2019 VanLeigh Vilano 320 GK
deltabravo
Spokane, WA
Posted: 07/23/21 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
When the CEL turned on, did you ever check to see what code was set? (Pxxxx) ?
Groover
Pulaski, TN
Posted: 07/23/21 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
I had pictures of the message but the code itself would disappear before I could get to a dealer. So all that it was doing was annoying the heck out of me.
