RV.Net Open Roads Forum: Water leaking from overflow valve on city water
 > Water leaking from overflow valve on city water
ricelake922
Peterborough
Posted: 07/24/21 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 1996 Monaco Dynasty and when I am using city water, there is water coming out of the valve under the RV. There is no water in the fresh tanks as I leave the drain valve open on the fresh tanks to make sure but water is still coming out of the valves. Please assist. Thank you in advance.
jdc1
Rescue, Ca
Posted: 07/24/21 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
Close the valves?
ricelake922
Peterborough
Posted: 07/24/21 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
Are you suggesting that I close the valve to the fresh water tanks? My mistake but the water appears to be coming out if the overflow valves under the RV. I have two of them.
Dutch_12078
Winters south, summers north
Posted: 07/24/21 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
If you have a use/fill selector valve or similar, make sure it's fully in the correct position. The other possibility is a faulty check valve in the water pump that's allowing city water to leak back through the pump into the tank. The tank drains and vent/overflows sometimes share the same outlets or are very close to each other.
Dutch
2001 GBM Landau 34' Class A
enblethen
Moses Lake, WA
Posted: 07/24/21 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
Valves under the rig are for draining the system. They should be in normal operation closed.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
ricelake922
Peterborough
Posted: 07/24/21 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
If I am using city water, why is the pump mentioned as a possibility of the reason the overflows are leaking water when on city water as I thought the pump is only used with fresh water tanks. Am I wrong?
Also, how does one shut the valves please as this has been suggested? I have a shut off valve that stops water going into the fresh water tanks but have never closed the overflow valves.
capacitor
California
Posted: 07/24/21 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
The pump has a check valve to keep water from going to the fresh water tank. It sounds like it is bad and allowing water into the fresh and out the drain. Fill the fresh tank and use the pump and no city water for this trip
Edit: the two valves you mention are probably the low point drains for both hot and cold. Close them.
Bill1374
northern New York
Posted: 07/26/21 08:27am Link  |  Quote  |  Print  |  Notify Moderator
From your description, I believe the valve you are talking about are the low point drains for the water system. In normal operation, they will be closed. Depending on the maker, they could be push-pull or quarter turn valves located somewhere above the point where you see the leak.
Try using the valve a couple of times quickly to clear the valve and see if your leak stops as debris may be preventing them from fully closing. Worst case may be to replace them.
KZ Montego Bay in Florida
Rockwood lite up north
2016 HD Street Glide, 12 Fatboy for cruisin
