RV.Net Open Roads Forum: Class A Motorhomes: Breaks and 12V system
 > Breaks and 12V system
FloridaRosebud
Melbourne
Posted: 07/24/21 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
OK, I've got a 2006 National SeabreezeLX, Ford F53 with the V-10. Today while driving 65mph on I-95 I lost all 12V and the engine died. I was able to get it to the berm, and troubleshooting showed the altenator died. So I fired up the Genny, and in a few minutes I had 12V to the Chassis battery and continued on, knowing that when we get to NY in a few days a new altenator is in my future.
However, my brakes were marginal when the engine died. So the question - what do I do if that were to happen again when I'm going down an incline in the mountains? When the engine dies power steering is lost as well.
Any thoughts?
Al
Dutch_12078
Winters south, summers north
Posted: 07/24/21 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
Your options in that situation are downshifting and using both feet on the brake pedal to get enough stopping pressure. When the engine died, the power steering pump also stopped, dropping the hydraulic boost pressure for the brakes and the power steering. Oh, and on a steep down hill, pray... [emoticon]
Dutch
2001 GBM Landau 34' Class A
opnspaces
San Diego Ca
Posted: 07/25/21 10:00am Link  |  Quote  |  Print  |  Notify Moderator
On a long downhill it's not going to be fun. A braking system holds only one maybe two pumps on the brakes in reserve when the engine quits. After those two pumps you're down to non assisted braking. As stated above you might need both feet on the pedal at that point, but the brakes will still work.
I have no idea if it would work. But if the engine quits you might try shifting the automatic transmission down to a lower gear. Worst case nothing happens as the transmission is freewheeling. Best case is you get some engine compression braking to help with keeping everything under control.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Bird Freak
Dallas Ga.
Posted: 07/25/21 11:29am Link  |  Quote  |  Print  |  Notify Moderator
Go ahead and have alt replaced. You have to do it anyway.
Eddie
03 Fleetwood Pride, 36-5L
04 Ford F-250 Superduty
15K Pullrite Superglide
Old coach 04 Pace Arrow 37C with brakes sometimes.
Owner- The Toy Shop-
Auto Restoration and Customs 32 years. Retired by a stroke!
We love 56 T-Birds
rgatijnet1
Posted: 07/25/21 11:31am Link  |  Quote  |  Print  |  Notify Moderator
Not familiar with an F53 but do you have a mechanical emergency brake that you can use to slow things down?
Beverley&Ken
Tottenham,Ontario
Posted: 07/25/21 11:44am Link  |  Quote  |  Print  |  Notify Moderator
Per opnspaces
“ I have no idea if it would work. But if the engine quits you might try shifting the automatic transmission down to a lower gear. Worst case nothing happens as the transmission is freewheeling. Best case is you get some engine compression braking to help with keeping everything under control. ”
A very interesting question, hopefully someone with real experience will chime in
With all the electronic systems in our vehicles, engine control modules, transmission modules , how much will actually work without and 12v power. Hopefully there is enough manual connection between the gear shift lever, the transmission and the rear wheels to assist in slowing down.
Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
valhalla360
No paticular place.
Posted: 07/25/21 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
As long as you are rolling, steering usually isn't a big issue.
The brakes still work but you now have to provide all the power. Biggest issue is recovering from the surprise. You may be used to supplying 5-10lb of pressure to the brake pad and suddenly, you need to apply 50-100lb of pressure. If you are slow to adjust, it may be out of control before you have a chance to react.
One question: Before the engine died, did the battery light come on or some other warning? Normally, you would have some warning if the alternator quit entirely but before the engine cuts out.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
wolfe10
Posted: 07/25/21 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
For voltage to go from "good" (i.e. over 12.8 VDC)to so low that neither the engine nor the electric brake boost would work doesn't sound like an alternator to me.
That assumes you were monitoring voltage.
More likely, there was a connection/fuse issue near the chassis battery. That would be more likely to result in voltage going from OK to doesn't work at all.
More insight on whether this WAS a sudden loss of 12 VDC or a gradual loss until voltage got so low that nothing running on 12 VDC would work would be enlightening.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
rgatijnet1
Posted: 07/25/21 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
Didn't the F53 have an ignition switch issue in the past. I seem to remember that there were issues where the vehicle would not start but a problem with the ignition switch could definitely cause a loss of 12 volt power to the engine. Simple enough to check with a voltmeter as to whether or not the alternator is working. Check the battery voltage with the engine off and then start the engine. If the voltage increases, then the alternator is not your problem.
FloridaRosebud
Melbourne
Posted: 07/25/21 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
Everything worked great today with the genny running. Battery connections (posts) are clean and good. After shutting down the genny I read 12.8V before I connected to shore power. I don't have my load tester with me (at home) but when we get to NY I will be getting a mobil guy out there. To add to the data, the little battery light has been flickering, indicating the output of the Alt is not good. In addition, with the genny off, the MH starts fine (after charging the battery), so that pretty much rules out the ignition switch as well.
AFA my question, thanks for the answers. If I loose 12V looks like I'll be standing hard on the brake with both feet.
BTW - I need to spell check my stuff....Breaks in the title....duh....
Al
