RV.Net Open Roads Forum: Class A Motorhomes: Breaks and 12V system
 > Breaks and 12V system
time2roll
Posted: 07/25/21 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
Was there no warning light or gauge to indicate low voltage? Usually voltage will creep down from 13, 12, 11, 10 volts over a few hours if the alternator is failed. Something should indicate this condition allowing you to start the generator etc and avoid the issue.
675w Solar pictures back up
FloridaRosebud
Melbourne
Posted: 07/25/21 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
It could have, but I did not notice it. I have no gauge, just a warning light.
Al
valhalla360
No paticular place.
Posted: 07/26/21 05:01am Link  |  Quote  |  Print  |  Notify Moderator
FloridaRosebud wrote:
To add to the data, the little battery light has been flickering, indicating the output of the Alt is not good.
Flickering could indicate a loose connection. This might have nothing to do with the alternator.
Starting later may just be that the loose connection is temporarily connected when sitting.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
time2roll
Posted: 07/26/21 07:44am Link  |  Quote  |  Print  |  Notify Moderator
Consider adding a voltmeter if the indicator is inadequate. This will give fair warning long before you lose power depending a hill or anything else.
FloridaRosebud
Melbourne
Posted: 07/26/21 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
OK, looks like we (mobil RV tech and myself) ran down the problem. So I have to eat crow and defer to a couple of you guys who called it - LOOSE BATTERY CONNECTION. Yep, the Alt is putting out what it should be, the converter on genny or shore power is putting out what it should, no apparent bad connections, EXCEPT the positive on the battery terminal, which we could move with our hands. While I could blame it on the pounding we've been taking on the trip up here (which has been insane), we were able to tighten all the battery connections, but the main chassis positive was in fact loose.
Lesson - every oil change check the battery connections as well, which I should be doing anyway when I check the water levels....
Al
Dutch_12078
Winters south, summers north
Posted: 07/26/21 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for letting us know the outcome, and I'm glad in the end it was an easy fix!
Dutch
2001 GBM Landau 34' Class A
FloridaRosebud
Melbourne
Posted: 07/27/21 02:35am Link  |  Quote  |  Print  |  Notify Moderator
Yeah, glad this one was easy. I'm just embarrassed that I missed something this simple.
Al
JRscooby
Indepmo
Posted: 07/27/21 04:18am Link  |  Quote  |  Print  |  Notify Moderator
I agree with the thanks. But I would like to point out that 99% of electrical problems are very easy to fix. The hard part is to find them.
Anybody that is good at finding the problems will start where he knows power is, and follow step by step until find where power is not.
