RV.Net Open Roads Forum: Great Tow Capacity - Bad Payload Capacity... Increase PL?
Search only in Tow Vehicles
 > Great Tow Capacity - Bad Payload Capacity... Increase PL?
Page of 6
SirKeats
Oregon
Posted: 07/24/21 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
So I have a 2016 Ram 2500 Megacab with the 6.7 Cummins. I love it. Great truck. It has plenty of tow capacity for us and our current trailer and possible future 5th Wheel upgrade at 16,936lbs.
The problem is that the payload capacity is absolutely horrible at only 1637lbs!!
We're looking to upgrade from our TT to a slightly larger (like 4 extra feet) 5th Wheel at some point, and after taking into account our family (people/pets) and what little cargo we carry in the truck, I'd need a pin weight of like 1000lbs to say within spec!! I checked... not gonna happen.
That said, is there anything that can be done to increase the payload capacity? I can easily stay under the tow/trailer capacity, I just need to be able to increase the pin weight capacity.
Like I said, I really like my truck. Would hate to have to up-size just to get a 5th wheel.
Thanks!
blt2ski
Kirkland, Wa
Posted: 07/24/21 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
You wont be the first, nor the last to have to upgrade chassy size to tow and equal sized 5W. One MAJOR problem of a 5W vs a TT is hitch weight! 10K TT has 1000-1500 lbs of HW. A 5w will have 200o-2500 lbs of HW for the same 10K trailer. How re you going to add this additional 1000-1500 lbs of payload to a given sized chassis truck? Your not!
Upgrade you must do!
Marty
Check RV.Net Blogs at: blog.rv.net
JIMNLIN
Oklahoma
Posted: 07/24/21 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
Rams Body Builders guide shows the 2500 Mega cab has a 6000 rawr. This will be on your drivers side door post.
The 6000 rawr on 3/4 ton Dodge Rams has been around for 25-30 years. The Mega Cab is a heavy beast. You have the truck so drop by a set of CAT scales and weigh your trucks front and rear axles separately.
I've seen some Mega cab owners report 3100-3200 lb rear axle which leaves around 2800-2900 lb payload before exceeding a tire/wheel or rear spring pack.
The axle is a 11.5" AAM with around 10800 lb rating from AAM. Dodge Ram derates it with smaller tires wheels and rear suspension.
There are no 3/4 ton LDT that can handle a 16k lb 5th wheel RV trailer that can have 3200-3800 lbs of hitch weight alone. Add the hitch and other gear/people and your overloaded.
Many mod their 3/4 or one ton srw trucks with rear leaf suspension with 19.5" tires/wheels. The 2500 Ram has rear coils but I'm not up on rear suspension help for coils. Others may know.
I pull a '97 28RK 11400 lb 5th wheel trailer (31' 10" length) with my old '03 2500 Dodge/5.9 Cummins quad cab short bed. The truck has the same 6000 rawr and is well under all axle weight ratings and tow ratings.
Your payload is a GVWR based payload. Some 3/4 ton trucks with high gvws may show a 3500-3600 lb payload sticker which over loads rear suspensions. Other trucks like yours with a low gvwr = low gvwr payload.
I would be looking for a one ton drw for a 17 lb 5th wheel rv trailer.
Posted: 07/24/21 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
Don’t worry about the truck. Coils are a bit soft on initial travel, but they are durable.
Literally nothing else to worry about up to about 7500 lbs on the rear axle, except spring rate. Payload number is a fake number to equal the magic 10klb gvw assigned to class 2 trucks until recent.
If it makes you feel better, I’m hauling somewhere between 1500-2000lbs tongue weight, on theOE hitch receiver, no weight distribution.
2017 Heartland Torque T29
MFL
Midwest
Posted: 07/25/21 05:08am Link  |  Quote  |  Print  |  Notify Moderator
With a FW, almost all wt is added to the rear axle. Your rear axle rating will be limited mostly to tire rating, as springs can be improved.
Know what your rear axle weighs, ready to camp, add hitch wt, and what is left, is useable pin wt of loaded to camp FW.
Jerry
southernsky
Ponchatoula La.
Posted: 07/25/21 05:16am Link  |  Quote  |  Print  |  Notify Moderator
At almost 17,000 lbs. your going to need a 1 ton truck.
2019 Ram 3500 Laramie DRW Crew Cab 6.7 H.O. CTD 4X4
2016 Grand Design Solitude 369RL 5th Airborne
WNYBob
Tonawanda, NY
Posted: 07/25/21 05:45am Link  |  Quote  |  Print  |  Notify Moderator
You can't change the sticker weights ( just ask the weight police on here).
There is a lot that goes into those numbers, axel, breakes and transmission to name a few. Yes you can add air bags other spring assists but willit be safe and stop you?
spoon059
Just north of D.C.
Posted: 07/25/21 05:57am Link  |  Quote  |  Print  |  Notify Moderator
Axle is the same between 2500 and 3500.
Rear differential is the same between 2500 and 3500 (although 3500 has other options).
Brakes are the same between 2500 and 3500.
Transmission is the same between 2500 and 3500 (although 3500 has other options).
If you have 18" wheels, they are the same between 2500 and 3500.
Engine is the same between 2500 and 3500.
Tires are the same between 2500 and 3500.
Frame is essentially the same, with the exception of mounting points for coils (2500) and leaves (3500).
2016 2500 Megacab with Cummins has a rear axle rating of 6500 lbs. 2016 3500 Megacab with Cummins has a rear axle rating of 7000 lbs.
Functionally, there is a 500 lbs difference between the 2500 and 3500 (when equipped with CTD). A 3/4 ton truck is class limited to 10,000 lbs, meaning that it can't weigh more than 10,000 lbs to be considered a class 2B truck. The way that manufacturers do that is to simply slap a sticker that says GVWR 10,000 lbs. OP, if you simply register your truck for a higher weight, you are perfectly legal and as safe as a 3500 to tow up to your axle limits. You'll stop the same, you'll be as safe (or no less unsafe) as you would in a 1 ton. Use common sense, not advertising jargon.
2015 Ram CTD
2015 Jayco 29QBS
wing_zealot
East of the Mississippi
Posted: 07/25/21 05:59am Link  |  Quote  |  Print  |  Notify Moderator
Your problem is tongue weight vs. pin weight. For any given weight trailer, the tongue weight of a TT will be approx. half the pin weight of a 5 er. So tell me again why do you want a 5er - so you can buy a new truck?
otrfun
On The Road
Posted: 07/25/21 06:57am Link  |  Quote  |  Print  |  Notify Moderator
The problem is that the payload capacity is absolutely horrible at only 1637lbs!! . . .
The empty rear axle weight on the Cummins equipped '16 Ram 3500 SRW megacab and '16 Ram 2500 megacab is nearly identical at ~3100 lbs. RAWR on the 2500 is 6500 lbs. (with 18" wheels/tires) and 7000 lbs. on the 3500.
Bottom line: you have approx. 3400 lbs. of rear axle capacity remaining on your 2500 (and 3900 lbs. of rear axle capacity remaining on a 3500 SRW).
Some folks will tell you don't have this rear axle capacity based on the lower payload and 10k GVWR, but the fact is, based on Ram's own specs, you clearly have 3400 lbs. of rear axle capacity on your '16 Ram 2500 Cummins megacab.
Since the Ram 2500 and 3500 SRW use 99% of the same components, it's easy to deduct the lower payload and 10k GVWR on the 2500 is solely based on the need to pigeon-hole a 2500 (in reality a 3500 SRW with slightly derated rear axle) into a class 2b (3/4-ton) rating for marketing purposes only. Nothing more, nothing less.
A lot of folks will say you need to upgrade to a 1-ton 3500 SRW. Not sure it's worth your time and money just to gain 500 lbs. of additional rear axle capacity.
* This post was last edited 07/25/21 08:17am by otrfun *   View edit history
Page of 6
