RV.Net Open Roads Forum: Great Tow Capacity - Bad Payload Capacity... Increase PL?
Search only in Tow Vehicles
 > Great Tow Capacity - Bad Payload Capacity... Increase PL?
Page of 6
valhalla360
No paticular place.
Posted: 07/28/21 04:34am Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
^It might be ok if you were actually right about what you’re talking about, but alas, you’re not. So in this case, it would be better to not say anything at all.
Please share your knowledge with the group.
10,000lb GVWR
7,400lb curb weight
So how do those two numbers limit the payload to 1,600lb?
I'll wait for you to do the math for us.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Devo the dog
Moved out of crazy California
Posted: 07/28/21 04:56am Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
spoon059 wrote:
valhalla360 wrote:
1600lb payload vs 2700lb payload
CTD vs V10... .
Guy was referring to the weight difference...
Correct Guy (valhalla360) was referring to the payload difference.. Then out of the blue, guy (spoon059 ) points out that the engine type and manufacture needs to be considered.
If someone else can make the engine and manufacture an issue, then so will I. Deal with it. Ram still sucks.
The dodge fan boys hate the dodge/ram dealerships. Now that I have owned a Mexican Fiat Oui-Oui (La fiat wee-wee), I understand why.
The only thing more incompetent than Ram is Bye-don and his supporters.
Devo the dog
Posted: 07/28/21 05:12am Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
4x4ord wrote:
The payload capacity is kind of a meaningless number on a sticker found on the door jam of your truck .... that can't be changed. If you want to increase the capability of your truck so it can handle a 3200 lb pin weight you'll have to upgrade your rear suspension. Install a set of air bags.
This is the real answer from someone who knows and works trucks.
The speculation from the rest of the peanut gallery (aka, the RVnet anti-airbag mafia (you know who you are, lol)) is just that...speculation.
True story from a different dodge cult member forum:
Guy buys new 2019 Fiat 2500 with factory air suspension and brags about what he can tow, shows pictures, etc. The reality is that he has been overloaded for years. Everyone tells him that he's overloaded. A few months into the 2019 ownership, factory airbags blow out while driving on the highway, and the full load falls on the rear suspension bump stops. He demands that Fiat replace the air bags under warranty. Then, he sells the repaired 2500 and buys a Fiat 3500.
All the dodge cult members are happy because the idiot gets a new Fiat 3500.
Moral of the story. A cult member is a cult member and air bags might not be the correct solution.
* This post was edited 07/28/21 05:31am by Devo the dog *
JIMNLIN
Oklahoma
Posted: 07/28/21 06:25am Link  |  Quote  |  Print  |  Notify Moderator
Troll alert !!!
IdaD
Idaho
Posted: 07/28/21 07:11am Link  |  Quote  |  Print  |  Notify Moderator
Imagine caring this much about something so unimportant.
2015 Cummins Ram 4wd CC/SB
n0arp
FT
Posted: 07/28/21 08:15am Link  |  Quote  |  Print  |  Notify Moderator
10,000lb GVWR
7,400lb curb weight
It's very simple. Actual scale tickets do not correspond with the weights on the resource you provided. A highly optioned MegaCab scaling 8300lbs isn't unheard of.
Here is FCA's official weight for a 2021 2500 4x4 MegaCab in *Big Horn* trim, which is a pretty low trim level. If OP has a Laramie, Longhorn, or Limitied, another few hundred pounds is easy to account for. 7954.57lbs. I pulled the numbers for 2016 as well, but they don't say what trims they're for. They publish a figure of 7,971 for 2016 in an unknown but likely base (Tradesman) trim.
Further, if you look at the chart, you can see that payload is an approximation (rounded to the nearest ten pounds) of GVWR - Total Base Weight.
10000 GVWR - 7950 Total Base Weight = 2050 Payload
My Longhorn DRW scaled over 8600lbs the day I brought it home. Payload is, not coincidentally, 5400lbs and GVWR is 14000lbs.
I have no idea who RoadSumo.com is, or where they got those numbers, but they're way off. The chart I provided is an excerpt from a document provided from FCA themselves, an actual authority on the subject. I don't understand why you would trust a third party resource like that when the data is provided by the manufacturer, unless you are attempting to cherry pick pieces to support your argument.
* This post was last edited 07/28/21 09:20am by n0arp *   View edit history
2021 Ram 5500 Limited 84CA Cummins 4x4 w/ flatbed
2020 Jeep Wrangler Unlimited Rubicon 2.0T (follow or TC toad)
2015 Keystone Alpine 3730FB 2925W/22.8kWh, 30K multi-split
2016 Arctic Fox 1140 WB 1800W/11.4kWh
BenK
SF BayArea
Posted: 07/28/21 10:11am Link  |  Quote  |  Print  |  Notify Moderator
You can only change the official OEM label ratings by hiring someone/company to re-certify & make the modifications they spell out in their certification paperwork, but that may cost more than just going out and purchasing a bigger vehicle.
You can also add/modify everything up to the AAM's 11000 GAWR, but the 'official OEM rating still stands'
Best to go out and actually weigh your TV axle by axle fully loaded as if going to tow.
Then subtract that from the OEM listed GCWR and that will be the OEM's official MTWR for your TV. Most are extremely surprised that their vehicle weighs more than the door labeled TV weight.
Then deal with the expected PIN weight vs your ACTUAL remaining TV rear axle payload .
-Ben Picture of my rig
ktmrfs
Portland, Oregon
Posted: 07/28/21 10:58am Link  |  Quote  |  Print  |  Notify Moderator
GM partially solved the problem a year or so ago by changing the classification of the 2500HD trucks and hence upping the std GVWR to 11,400ish for a 2500 SRW. Option is a <10K GVWR for those who have a reason for a lower GVWR.
So now the 3/4 ton GM and 1 ton SRW have basically the same GVWR.
2011 Keystone Outback 295RE
mkirsch
Rochester, NY
Posted: 07/28/21 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
The long and short of it is, you can put higher-rated tires on it, and shore up the suspension with aftermarket parts to handle the weight.
No matter what anyone says, that does not change the numbers assigned by the manufacturer, but you're planning on ignoring those numbers anyway, so who cares?
What you're really asking is if someone else will take the blame if something happens. The answer to that is no. It's all you.
4x4ord
Alberta
Posted: 07/28/21 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
If something happens? Like an accident? Accidents do happen and it's usually someone's fault .... so for instance if I run over a pedestrian in a crosswalk does it make any difference whether I'm over my GVWR or not .... either way it's my fault ... either way I expect my insurance to pay. If my insurance won't pay when it is my fault, I don't imagine they're going to pay when it's not my fault. Can you find evidence to support a theory that loading a truck over the GVWR set by the manufacturer is illegal?
2021 F350 SRW Platinum short box 4x4.
B&W Companion
Page of 6
