RV.Net Open Roads Forum: Fifth-Wheels: Jacking up 5th wheel?
 > Jacking up 5th wheel?
laknox
Arizona
Posted: 07/26/21 09:22am Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
Simple and safe method to do any repair. I have used on my 19 and 24k Mobile Suites 5er's.
But, but, but... That will overstress the one tire by putting too much load on it, same as driving over a curb at low speed!
(/sarcasm)
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 64 Year Member
laknox
Arizona
Posted: 07/26/21 09:24am Link  |  Quote  |  Print  |  Notify Moderator
riltri wrote:
When you jack up your 5th wheel do you:
- place the jack under the axle between the hanger u-bolts
- jack up the frame
- use a ramp to drive the good tire onto
- other...please explain
I know I'll catch **** for it, but if it came down to it, I'd use my 4-point leveling system to jack the whole rig up. Each jack is capable of lifting nearly the whole GVW of my KZ, so 2 should work well, let alone all 4. Just leveling my rig out in the street in front of my house leaves the curb-side tires off the ground about 2".
Lyle
* This post was edited 07/28/21 08:00am by an administrator/moderator *
Cummins12V98
on the road
Posted: 07/26/21 09:25am Link  |  Quote  |  Print  |  Notify Moderator
(/sarcasm)
Lyle
I know, I should be ashamed posting such a thing. [emoticon]
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
BB_TX
McKinney, Texas
Posted: 07/27/21 08:29am Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
(/sarcasm)
Lyle
Yeah, 6,000 lbs on a tire rated for less than 4,000. And 6,000 lbs this side plus 3,000 lbs on the opposite side on an axle rated for 6-7,000 lbs. No worry. [emoticon]
cummins2014
Utah
Posted: 07/27/21 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
- jack up the frame
Lyle
Glad you mentioned it ,was going to pm the OP to use level up . I have replaced the tires, doing that ,and taking them to the tire shop. Also did my bearings ,and new brake shoes that way recently . I can catch he!! with you . [emoticon]
* This post was edited 07/28/21 08:02am by an administrator/moderator *
dieseltruckdriver
Black Hills of SD
Posted: 07/27/21 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
Add me to the list. I carry a bottle jack, but I always use the 4 point leveling. We camp in some places that lift the tires, so I don't see any difference.
* This post was edited 07/28/21 08:04am by an administrator/moderator *
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
Cummins12V98
on the road
Posted: 07/27/21 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
Typically I will use my 6 point system but there are times the TrailerAid works well.
cummins2014
Utah
Posted: 07/28/21 07:34am Link  |  Quote  |  Print  |  Notify Moderator
Good to see a few more confessions [emoticon] It goes without saying , I wouldn't be getting under that fifth wheel without safety stands . But its great for tire changing or wheel bearing or brake service. No I don't pump grease into my bearings ,EVER [emoticon]
Veebyes
Posted: 07/28/21 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
Asking for trouble if you put the jack under the curved U bolt.
Put it under the lowest spring leaf next to the axle. A flat surface not prone to slipping.
2007 Alpenlite 34RLR
laknox
Arizona
Posted: 07/29/21 09:30am Link  |  Quote  |  Print  |  Notify Moderator
Or you could buy, or make, something like THIS.
Lyle
