RV.Net Open Roads Forum: Truck Campers: Black tank treatments.
 > Black tank treatments.
specta
utah
Posted: 07/26/21 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
Back when i bought my first RV everyone recommended adding Calgon and Camco TST to your black tank.
Do people still recommend adding stuff to their black tank?
Are you adding anything to yours?
Kenny
2011 Chevy 2500 HD 6.0L 4wd
1976 Ford F-250 6.4L 4wd
fpoole
PNW and Beyond
Posted: 07/26/21 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
"Happy Camper", been using it for 5+ yrs, no problems and makes me a Happy Camper.. also, occasionally used in Gray tank, just mix with water and pour it in...
Frank Poole
Roam'n ROG (Full Timer since Oct '15)
2016 RAM 5500, C/c, 6.7 Diesel, AISIN HD 6-spd, 19.5 DRW, 72 Gal fuel, 4x4, 10’ Alum FB, 440 Amps, 4.10 Axle
2016 AF 990 640-Solar/10-6v Batts
GlowStep Stow N’ Go, E-Bike
RS1 Buggy
frank
Pooles website
jimh406
Western MT
Posted: 07/26/21 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
We just use Thetford Aqua-Kem. I’ve tried other stuff, but we like the smell of the blue stuff more than smells created by the other brands.
srschang
Western NY
Posted: 07/26/21 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
Agree with Thetford Aqua-Kem, it just plain works. But it works because it contains Methyl Alcohol and Formaldehyde, which I think is bad for my septic tank at home. So if I'm going to dump at home or in another septic tank, I use Thetford Campa-Chem, which sort of works unless it's real hot. It is "Formaldehyde Free!" according to the label. It contains Bromo-Nitropropane-Diol and surfactants. I guess I should find out how that affects a septic tank!
2022 Ram 3500 Dually Crewcab Longbed Cummins, 2019 Northstar 12 STC
Kayteg1
California > Nevada
Posted: 07/26/21 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
Never used any chemicals in my tanks.
Owens River area
Posted: 07/26/21 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
Plenty of water and frequent dumping is my preferred method.
jdc1
Rescue, Ca
Posted: 07/26/21 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
25+ years...never needed anything. Maybe add granulated laundry detergent once a year.
SoonDockin
Oklahoma
Posted: 07/26/21 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
Ive been using calgon, laundry soap and a bit of bleach every time I empty the black tank. I have on rare occasion done nothing if planning to dump on day two. My tanks flush out clean never smell, unless I push it for 5 days or so. Which I did once in mid summer.
2019 Ford F450 KR
2018 Arctic Fox 1140 Dry Bath
Kayteg1
California > Nevada
Posted: 07/26/21 11:03pm Link  |  Quote  |  Print  |  Notify Moderator
Bought my 1st motorhome in 1987.
Small tanks in ClassC did generate some crud on the walls, but once a year treatment with ice cubes kept them clean.
I never hesitated to use lot of water and with 3 sons there was always lot of liquid in black tank.
towpro
Compass PA
Posted: 07/27/21 07:40am Link  |  Quote  |  Print  |  Notify Moderator
I used to use tanktechsRX in my truck camper which was always moving which breaks up the solids it worked great.
But when I used it in my 5th wheel that sat all the time it did not stop the stink. In this situation AquaKem worked well.
but after I traded in everything on the MH I had a supply of aquaKem left so that went into the MH.
Forest River Forester 2401R Mercedes Benz.
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
