RV.Net Open Roads Forum: Class C Motorhomes: Dingy towing
 > Dingy towing
NC4ME
NC
Posted: 07/28/21 08:53am Link  |  Quote  |  Print  |  Notify Moderator
My jeep has the RV brake system in it so braking is no problem.
GGoodsell
Lincoln, CA
Posted: 07/28/21 09:39am Link  |  Quote  |  Print  |  Notify Moderator
Just got back from a trip into California's Sierras. Towed my 3,500 lb. Honda CRV up over 7,000'. Several 6 and even 7% grades. Dropped to 43-45 mph on most, let the transmission do its thing, never touched the shift lever. RPMs got to 4,000+ and the cooling fan was noisy. Saw the temp gauge briefly get above halfway, heard the fan increase speed and the temp came right back down to normal. RV is a 2018 28' class C on a Ford E 450 chassis. You won't have any problem.
cbigham
orange , CA
Posted: 07/29/21 08:11am Link  |  Quote  |  Print  |  Notify Moderator
Got a 23u thor chateau, e450 2017. Just got back recently towing a jeep unlimited Rubicon, 300 lbs motorcycle and rack on back. Cargo bay filled. .. Idaho, Wyoming, NV, CA deserts 110+ heat. Jeep has brake system. This trip like many before it,
You'll be fine.??????
Matt_Colie
Southeast Michigan
Posted: 07/29/21 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
DRTDEVL wrote:
There is no "charge air" in a naturally-aspirated engine.
Aside from that, the advice is solid.
Drtdevl,
You are obviously not a refugee from the engine labs of Detroit.
Change Air is what every IC engine sucks in. It can be atmospheric pressure, it is still charge air.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs going to see some dry places that have Geocaches in a coach made the year we married.
pauldub
North of Seattle
Posted: 07/30/21 08:59am Link  |  Quote  |  Print  |  Notify Moderator
If you know how to select a proper gear for the grade, overheating should not be a problem if you are not exceeding the GCVWR (gross combined vehicle weight rating). I've towed my 4Runner over 12,000 foot passes with my '03 Winnie. Mine is 24' so I have a lot more of the GCVWR that isn't consumed by the motor home gross weight. You need to weigh the motor home and the jeep then do some simple math to see where you are.
 > Dingy towing
