RV.Net Open Roads Forum: Tech Issues: Strange electrical problem
 > Strange electrical problem
agesilaus
North Florida
Posted: 07/27/21 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
OK right now my converter is charging the batteries but when I am off shore power I'm not getting any 12V power. When I am off 120V the 12V bus at the battery end is hot with 12V. After watch a number of YT videos I finally came across one that may point to the problem.
Apparenty the charging wiring to the battery is separate from the 12V from the battery and they are found inside the power distribution box.
I have a Progressive Dynamics PD50K3Q2GP Panel --30amp panel. My problem is getting that panel box open, it seems as if there are two tiny connectors, one on the left side and one on the bottom but I can'yt tell what will open them:
Any suggestions?
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
Gary45
Oshawa, Ontario, Canada
Posted: 07/27/21 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have fuses in battery location (Mine does) - one of the fuses will be the charging circuit
agesilaus
North Florida
Posted: 07/27/21 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
I'll double check that, I haven't seen any. The wiring just goes thru a wall w/o fuses. But there is a space under the camper where they come together, I'll open that up.
enblethen
Moses Lake, WA
Posted: 07/27/21 02:44pm Link  |  Quote  |  Print  |  Notify Moderator
Quick look, your panel has two 12 volt DC inputs which means you should have two fuses.
Look at bottom of this for information.
Manual
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
agesilaus
North Florida
Posted: 08/04/21 10:14pm Link  |  Quote  |  Print  |  Notify Moderator
OK an update, I identified the cable coming from the battery. Went out and bought 20 feet of No4 cable ran that outside the camper as a test from the 12V hot side at the batteries to the distribution block. Checked it against the bare ground wire at the dist. box end with 120V on, got 12V. Shut 120V off that same end now dead but it still has 12V at the battery end??!!
I'm beginning to think this may be a ground problem, what else could explain it?
Thinking about trying a No10 wire from the battery ground to the dist box, any thoughts on that?
There are NO fuses unless they are buried deep inside the camper belly.
BTW the original cable from the battery is distinctly smaller than the stuff I bought.
wopachop
Who run bartertown
Posted: 08/04/21 10:33pm Link  |  Quote  |  Print  |  Notify Moderator
You could get an extension cord. Use a clamp to touch a prong to the negative wire where it attaches to the battery.
Run the extension cord over to your panel and check for continuity between the cord and the negative at the panel.
enblethen
Moses Lake, WA
Posted: 08/05/21 06:24am Link  |  Quote  |  Print  |  Notify Moderator
Put the test wire on the negative, then check for resistance between bare wire and it. You should be testing to the battery negative. The bare wire should be tying the 120 volt system to the chassis of your rig. Have you verified the battery negative connection at the battery?
agesilaus
North Florida
Posted: 08/05/21 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
OK finally fixed. I just decided to install a new ground wire from the battery negative to the frame. Drilled a hole, used some #10 wire to a self tapping screw. Tested, now have 12 when off shore power.
That opens up boondocking ahead. What a pain tracking down these electrical problems can be. Fortunately the Mobile repair guy I called yesterday never called back so that saved us several hundred bucks anyway.
I can use that 20 feet of #4 wire to hook up the inverter when I get the solar system fully installed.
Thanks for all the suggestions and help. I can only wonder what happened to the original ground wire that worked for 2 years+
enblethen
Moses Lake, WA
Posted: 08/05/21 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
Self tapping screws are not the best. I would have used a bolt, star washer and nut. Clean frame good with wire brush? Coat the connection with electrical grease.
