dessa1930
north carolina
i want to replace my duel cam bar lift chains
are there a special chain i need to buy
my tounge weight is around 800 lbs
thanks
johntank
North MS
Don't know if they are special or not, but I would think a grade 70 chain in the size need would do, a 5/16" grade 70 chain has a working load limit of 4700#
BurbMan
Indianapolis, IN
Take one off and take it to the home center, get the same size, it's probably 5/16". Pro tip: Get galvanized chains, they will stay looking nicer longer.
2008 Heartland Big Country 3250TS
SOLD: 2002 Lance 811 Slide-In Camper
2002 Lance 811 Renovation Story!
QCMan
Independent Republic of Horry
Or go to a marine supply and get stainless chain. It will always look good.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
capacitor
California
Curious, why are you replacing them?
dessa1930
north carolina
i think i have to much lift and i am at the end of the link
so i am going to get some with a couple of links longer to see if that makes a difference
BarneyS
S.E. Lower Michigan
All you need do is tilt the hitch head forward towards the tow vehicle and that will lift the bars higher to begin with so you don't need as many chain lengths to lift them and/or will reduce the amount of lift with the same chain link used.
You must not be transferring much, if any weight forward now if you are at the end of the chain. The Dual Cam requires some pressure on the cam/bar interface for the system to work correctly. I frankly have never heard of anyone running out of chain links in order to properly tune their hitch setup. Why do you think you have too much lift?
Barney
Not towing now.
LITEPHIL
AZ
Yes, adjust the head angle. The chains don't wear out and I would feel better with the chains that Reese supplies.Remember, the bars should be some what parallel to the frame when set up.
2022 Chevy Silverado RST Duramax NHT
1954 Chevy 3100 Carryall 4x4
2008 Salem T23FBL
04 FXDL Harley
