RV.Net Open Roads Forum: Tow Vehicles: Ultimate payload monster?
Search only in Tow Vehicles
 > Ultimate payload monster?
Page of 7
rjstractor
Maple Valley, WA
Posted: 07/28/21 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
GVWR is a JOKE!!! Someone please tell me how I can stay at or under 14k when my RAWR is 9,750# and my unloaded front axle weight is 5,250# when they add up to 15k. My solution is to have tonnage enough to cover my 6 tires load.
Even worse with my 2000 F250 diesel, to get to its 6100 lb or so RGAWR without exceeding its 8800 GVWR, I would have to pile all the weight behind the rear axle to unload the front axle from its 4500 lb or so empty weight to under 2800 pounds. Far safer to load the truck at 5500 on the rear, 4500 on the front even though at those weights I'm exceeding the GVWR by 1200 lbs.
CA Traveler
The Western States
Posted: 07/28/21 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
GVWR isn't just about dead weight. Consider suspension, brakes, stopping distant, stability when turning/swerving, weather, road conditions etc. Maybe other factors like mfg libiality etc.
2014 Grand Cherokee Overland
Bob
blt2ski
Kirkland, Wa
Posted: 07/28/21 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
Nothing "ILLEGAL" about either of these options. Reality per federal bridge laws, Cummins can go to 32k gvw, 20k on rear 12k or so on FA before being over the FBL standards.
RJ can hit 10-12k on his two axles ALSO before being over wieght per FBLs.
There are other issues that will get them off the road... Wieght will not be an issue, assuming they have the correct paid for tonnage.
Just like I've been pulled over multiple times, been thru DOT scale house upwards of 26000 gvw, I have yet to get an overweight ticket. Even tho door jam tag says gvwr is 18200. By the way, door tag sticker is in OM in my office.
A lot of what others have implied are correct if your going after manufacture warranty performance ratings. Add more options, get a heavier engine, tranny, dual alternators, AC, power windows etc, ALL take away payload, assuming FA and RA have the same numbers. Ext cab also heavier than regular, crew is heaviest yet.
Choose poison, hope it works for you, how you want to use it......
Marty
2014 Chevy 1500 Dual cab 4x4
Posted: 07/28/21 09:52pm Link  |  Quote  |  Print  |  Notify Moderator
Meh….
Easier to consider learning how to drive than worrying about all that fodder!
2017 Heartland Torque T29
JRscooby
Indepmo
Posted: 07/29/21 05:40am Link  |  Quote  |  Print  |  Notify Moderator
I ain't much smarter than a box of rocks, but I would guess there might be other components that limit GWR?
BTW, I don't think I have ever seen a weight tag where the total of axle weights is not greater than GVWR.
Grit dog wrote:
Meh….
IMHO, when it comes to hauling or towing, knowing your actual weigh, how it compares to ratings of you vehicle, and how it can effect " stopping distant, stability when turning/swerving" is a pretty important part of "learning to drive", but you do you.
rhagfo
Portland, OR
Posted: 07/29/21 07:16am Link  |  Quote  |  Print  |  Notify Moderator
Marty
I find it interesting that a moderator would say that federal bridge laws make it legal to exceed the listed axle and tire ratings on truck.
Once you exceed GVWR you hit a grey area. While axle and tire may be considered legal to some, a lawyer will go after the statement in owners manuals that is is unsafe to exceed any of the weight numbers on the VIN tag.
blt2ski
Kirkland, Wa
Posted: 07/29/21 07:57am Link  |  Quote  |  Print  |  Notify Moderator
Russ,
I would suggest you and others look up HOW weights are enforced on highways etc. Manufacture labeling us not enforced. OR if the road you are driving on has federal funds to it, your state enforced a lower standard, funds can be held from said state. Granted some exceptions do apply, frozen thawing ground, a lower axle limit can be applied.
Getting an over wieght ticket is a non moving violation. It does not go against driving record.
WHERE an Leo/cveo will get you if over a manufactures rating, they will do a field test braking your rig. You don't stop in X ft, at y mph. Ie about 10-29 mph, you have a failed braking system. THAT is a moving violation. Ticket goes against driving record. Vehicle is red tagged. It cannot beover off road on its own power. Or it needs to be fixed where it sits. This hurts ones pocket book from a legal standpoint
IF you want to to talk getting sued after an accident etc in civil court. That's another can of worms. Even if I'm under ALL of my legal wts etc, depending upon injuries etc, I can still lose my shirt, house etc.
Marty
Cummins12V98
on the road
Posted: 07/29/21 09:42am Link  |  Quote  |  Print  |  Notify Moderator
GVWR is all about licensing and keeping it in a certain weight class.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
on the road
Posted: 07/29/21 09:47am Link  |  Quote  |  Print  |  Notify Moderator
No one is going to respond directly to my question of how my SAE rear axle rating plus unloaded front axle weight is 1.000# over my 14k GVWR???
ktmrfs
Portland, Oregon
Posted: 07/29/21 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
maybe not all, but certainly a big part of it. "3/4" ton trucks usually fall under class 2? rating which is GVWR<0=10,000lbs. so at least part of the rating is the class. GM last year or so finally bit the bullet and has the 2500HD as a class III so the SRW has a GVWR of around 11,400 similar to a 3500SRW. Now if you want less for licensing as expected there is a <10,000 GVWR option, just like on the 3500's SRW.
And IIRC the 1/2 tons class rating is <=8800 lbs.
2011 Keystone Outback 295RE
Page of 7
