RV.Net Open Roads Forum: New, low cost 100Ah 12V LiFePO4 battery !
 > New, low cost 100Ah 12V LiFePO4 battery !
theoldwizard1
SE MI
Posted: 07/28/21 07:33am Link  |  Quote  |  Print  |  Notify Moderator
$399 100Ah 12V "Zooms" LiFePO4 Battery Review
Buy on Amazon !
* This post was edited 07/28/21 02:05pm by theoldwizard1 *
bgum
South Louisiana
Posted: 07/28/21 07:52am Link  |  Quote  |  Print  |  Notify Moderator
I see 749
IAMICHABOD
Sunny So Cal
Posted: 07/28/21 08:02am Link  |  Quote  |  Print  |  Notify Moderator
bgum wrote:
I see 749
And an F Rating[emoticon]
Former El Monte RV Rental
Buying A Rental Class C
NamMedevac 70
Reno
Posted: 07/28/21 08:19am Link  |  Quote  |  Print  |  Notify Moderator
IAMICHABOD wrote:
bgum wrote:
I see 749
Fakespot is a fraudulent company
They are pretending to be unbiased and legitimate when in fact their "algorithm" is broken and the results are completely incorrect. It's a good thing no one uses fakespot or even knows about this terrible company.
Read Customer Service Reviews of fakespot.com - Trustpilot
According to Trustpilot.com Fakespot is a fraud then maybe Trustpilot is also a fraud????????
theoldwizard1
SE MI
Posted: 07/28/21 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
bgum wrote:
I see $749
Yes,that is the 200Ah version. The 100Ah is currently out of stock.
rlw999
Washington State
Posted: 07/28/21 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
Given the power density of batteries and the danger of a fire in an RV, I'd never buy a cheap off-brand.
To put it in perspective:
A 100Ah 12V battery has around 1.2KWh of energy stored in it, 1 Watt-Hour has 3600 Joules of energy, so 1.2KWh has 1.2 * 1000 * 3600 = 4.3 million Joules of energy.
A hand grenade contains around 50g of TNT, at 4,000 Joules/g, that's around 200,000 joules.
So a 100Ah battery has the same energy as around 20 hand grenades. Granted, the battery is not going to release all of that energy at once, but still, a failure can do a lot of damage.
Here's what happens when you puncture one (no explosion, but an impressive jet of flame): https://www.youtube.com/watch?v=07BS6QY3wI8
StirCrazy
Kamloops, BC, Canada
Posted: 07/29/21 08:51am Link  |  Quote  |  Print  |  Notify Moderator
the first test he did shorting the termanals, which did nothing aside from melt the termanals, would have caused a lead acid battery to expload. right there it is safer than a normal battery, as that would be the most comon issue from people working around there batteries. and it isnt like the old nickel metal hydride batteries that are subject to thermal runnaway, but I guess if you go around shoving metal spikes through the battery..... maybe thats why they are in a protective case?
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
theoldwizard1
SE MI
Posted: 08/01/21 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
The only reason I mentioned this battery is because it got a very high rating from Will Prowse. $399 100Ah 12V "Zooms" LiFePO4 Battery Review
If you have not seen any of his YouTube video you need to know that he has been evaluating and testing solar equipment for over 4 years. I trust his opinion.
StirCrazy wrote:
The first test he did shorting the termanals, which did nothing aside from melt the termanals, would have caused a lead acid battery to expload.
Concur !
This is why a fuse should be as close as possible to the positive terminal on the battery and the positive post needs additional protection.
SoonDockin
Oklahoma
Posted: 08/02/21 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
I ended up getting two 206ah SOK batteries based on Wills review and continued positive comments. Hope to have them soon. Now its time to remove the vents from my battery storage.
2019 Ford F450 KR
2018 Arctic Fox 1140 Dry Bath
StirCrazy
Posted: 08/02/21 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
I like the way they did the case for thoes ones.
Steve
