RV.Net Open Roads Forum: Fifth-Wheels: Looking for Recommendations on Floor Jacks
 > Looking for Recommendations on Floor Jacks
Bunker
Posted: 07/28/21 09:24am Link  |  Quote  |  Print  |  Notify Moderator
I am going on a long road trip and I am trying prepare. Do you all use a floor jack when you have blow outs or do you just use the truck's jack? I was looking at getting 1 1/2 ton floor jack to carry with me.
Thanks.
CA Traveler
The Western States
Posted: 07/28/21 09:32am Link  |  Quote  |  Print  |  Notify Moderator
A bottle jack or mechanical jack would be much smaller and lighter.
2014 Grand Cherokee Overland
Bob
Cummins12V98
on the road
Posted: 07/28/21 09:43am Link  |  Quote  |  Print  |  Notify Moderator
Much safer than crawling under the RV. TrailerAid Plus is lightweight but plenty strong enough to carry this 7k load.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
jdc1
Rescue, Ca
Posted: 07/28/21 09:54am Link  |  Quote  |  Print  |  Notify Moderator
What "Cummins12V98" says...but the economy model...aka wood blocks.
2oldman
NM
Posted: 07/28/21 10:38am Link  |  Quote  |  Print  |  Notify Moderator
I assume you mean for the 5er. I've had one flat in 18 years. Used a 12 ton bottle jack.
ssthrd
Vancouver Island
Posted: 07/28/21 11:38am Link  |  Quote  |  Print  |  Notify Moderator
^ What I have + wooden blocks.
2014 Keystone Laredo 292RL
2011 Palomino Maverick 800M
2018 GMC 3500HD, 4x4, 6.5' box, SRW, Denali, Duramax, Andersen
DeeBee, JayBee, and Jed the Black Lab
The hurrier I go the behinder I get. (Lewis Carroll)
JIMNLIN
Oklahoma
Posted: 07/28/21 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
truckers Special 12t shorty hyd bottle jack placed under the axle next to the U bolt. This lifts one end of the axle enough to remove the flat and install the spare.
If you use the drive on blocks make a dry run at home. Some have found out the drive on ramp wasn't tall enough.
JRscooby
Indepmo
Posted: 07/28/21 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks.
Many do that carry a floor jack do not understand when you need that jack you are unlikely to have a major component required to safely use that jack, the floor. They are designed to operate on a hard smooth surface. As the lift platform goes up, it moves back in relation to wheels. On a floor, the carriage rolls to stay under load. Most times on the side of road the wheels sink, the platform slips on axle, vehicle falls.
Test at home is a good plan no matter what system you use.
memtb
Wyoming
Posted: 07/28/21 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
I’ve used bottle jacks for many years on my trailers, I even went so far as to, cut a pipe coupling (larger than the trailer axle) in half and weld it to the top of the jack ram. It makes for a very secure, stable jack point.
However, on our 5er, I just used the hydraulic auto leveling to lift trailer high enough to change a tire or whatever maintenance required ( tire rotation, bearing pack, brake work, ect)! [emoticon] memtb
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
RAS43
Littleton,CO
Posted: 07/28/21 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
Same here w/ 1 blowout in 40+ years of pulling trailers. Keep it simple. And I don't believe a 1 1/2 ton floor jack is enough for anything but a car.
