RV.Net Open Roads Forum: Truck Campers: Toilet Tissue...
 > Toilet Tissue...
Page of 5
valhalla360
No paticular place.
Posted: 07/28/21 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
Kayteg1 wrote:
Old-fashioned test it put chunk of paper into a jar, add some water and shake it for few seconds.
If the paper breaks on small pieces it is good.
We've been using Costco paper for few decades just fine.
Even easier test...if your fingers go right thru it and you have to wash brown stuff off your fingers, it's RV safe.
We just use normal TP and plenty of water.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Longshore
California
Posted: 07/28/21 01:22pm Link  |  Quote  |  Print  |  Notify Moderator
Appreciate the input!
Kayteg1
California > Nevada
Posted: 07/28/21 01:37pm Link  |  Quote  |  Print  |  Notify Moderator
IB853347201 wrote:
Single ply is the way to go. Any brand will do.
When I seldom use those, the few I found at public restrooms would not dissolve.
Big chunks of paper can not only stick to the tank wall, but can fool drain valve.
Monterey, California
Posted: 07/28/21 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
I use what Dick B does! lol Scott’s single ply.
wildtoad
Blythewood, SC
Posted: 07/28/21 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
specta wrote:
Use any toilet paper you want, RV toilet paper is a rip off.
If you are going to use a lot of water then this is good advice. However if you don’t use lots of water, and people in your RV use a roll every day, then use single ply tp.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Pangaea Ron
Anacortes, WA, USA
Posted: 07/28/21 02:49pm Link  |  Quote  |  Print  |  Notify Moderator
As I remember, a student did the ultimate TP evaluation for her junior high school science project, Soaking it in water, shaking, etc., and determined that Angel Soft performed the best.
I'll try to find a reference to it on this Forum?
2008 Itasca SunCruiser 35L
2014 Honda AWD CR-V EX-L
TxGearhead
Posted: 07/28/21 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
Wife will only use Scotts RV paper. So...
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
mbloof
Beaverton, OR
Posted: 07/28/21 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
+1 Costco TP
I use the same TP in the camper as I do at home. Never a issue.
Then again, the RV's I've had have small black tanks, I use Aquachem and lots of water.
- Mark0.
352
Oxfofd, Fl
Posted: 07/28/21 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
If you get to the point where you have the P@@P pyramid try this. If you had the pyramid problem proceed as follows. Reach your hand down the hole as far as possible. When you feel anything chunky squeeze it between your fingers until it not chunky. Put 5 gallons of water down the hole and put you arm back in and swirl it around. Give it a few minutes and letr rip. Hope this helps. I have a low cost video of this if you need further instructions
The manatees of Halls river Homosassa Springs Fl
1985 Chevy Silverado c10. 454 stroker / 495 CI = 675 HP. 650lb of torque. Turb0 400 tranny. 3000 stall converter. Aluminum heads. 3 inch exhaust flowmasters. 2 inch headers. Heat and air. Tubed.
Sandia Man
Rio Rancho, NM
Posted: 07/28/21 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
We have always used whatever TP we have in our house, we buy the big box of POM 2-ply from Samsclub. Everybody has their methods and their reasoning behind them, similar to what chemical or concoction they use for their black tanks, for either issue the solution is using plenty of water.
When RVing in the summer we use the cheapest deodorizing chemical from Walmart without regard to brand, rest of the year just H2O. We backflush every time we dump, at least once a year we use a tank wand to get the nitty gritty off the sides and bottom of tank, not much TP is stuck inside.
Page of 5
 > Toilet Tissue...
