RV.Net Open Roads Forum: General RVing Issues: Portable gas detector
 > Portable gas detector
Brownleaf
Durham
Posted: 07/28/21 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
Rather than depending on that lp detector down on the side near the floo r, are there not some new Kidde type gas detectors that have a 10 year battery and I would not have to worry about the wiring on that inset one ?Im no t handy electrically and short on funds, i think the one on the floor is dysfunctional- Thanks Doug
SAR Tracker
Central Oregon
Posted: 07/28/21 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
Google is your friend.....
Rusty & Cheryl
2011 F250 2WD 6.2L Gasser
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
Boon Docker
Posted: 07/28/21 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
Good luck with Google.
I don't think you will find a battery operated (9 volt or double battery) LP gas detector besides the 12v hard wired models.
rlw999
Washington State
Posted: 07/28/21 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
Most LP gas detectors draw too much power to run off a small 10 year battery like some of the new sealed smoke/CO detectors -- the ones typically used in an RV use one or two amp-hours a day. Not too bad when you power it from a 100 amp-hour house battery.
But one amp-hour @ 12V is 12 Watt-hours. A single AA sized lithium battery will provide a few Watt-Hours of power, so you'd need 4 of those batteries to power the LP detector for a single day.
You can buy a replacement for that floor mounted one for $50 or so, if you're not able to replace it yourself, it's a quick job for a repair shop or handyman. But whatever you do, put the replacement low to the floor since LP gas is heavier than air.
craig7h
Branson MO area
Posted: 07/29/21 04:54am Link  |  Quote  |  Print  |  Notify Moderator
My question is why do you think the floor detector is not working? It really only has one purpose thats to shut off the propane. So if your stove is working so is the lp detector.
If you are concerned about carbon monoxide get a good RV rated tester to put on the ceiling.
Itasca Meridian SE 36g
Road Master Tow Dolly
prichardson
Lafayette, La
Posted: 07/29/21 07:41am Link  |  Quote  |  Print  |  Notify Moderator
Most LP detectors will not shut the LP system off. They will only warn you of its presence.
IAMICHABOD
Sunny So Cal
Posted: 07/29/21 07:56am Link  |  Quote  |  Print  |  Notify Moderator
One with a 10 year battery would not be practicable, Most LP detectors have a lifespan of 5 or 6 years. I have had 2 die just past their 5 year manufacture date.
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
C.B.
APPLETON WI USA
Posted: 07/29/21 08:01am Link  |  Quote  |  Print  |  Notify Moderator
IMHO
Pinching pennies on LP & carbon monoxide detectors is NOT a good idea.
C.B.
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE~
PRODIGY CONTROLLER~C-BETR MIRRORS~EMS-HW50C~
Butch/Barb=2013-Cedar Creek 36CKTS
Kris/Katy=2006-Cherokee 32B
dedmiston
Coast to Coast
Posted: 07/29/21 08:26am Link  |  Quote  |  Print  |  Notify Moderator
Not to go all Andy Rooney here, but (say it in his whiny voice) don't you hate it that the detectors in RVs don't have a standard size and form? Everyone knows the smoke, C0, and LP detectors are going to go bad and most of them are cut into the walls. So how are we supposed to find a replacement that will perfectly fit back into the hole in the wall?
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
C.B.
APPLETON WI USA
Posted: 07/29/21 09:25am Link  |  Quote  |  Print  |  Notify Moderator
Take the make /model number off old one. Find it at camping world, amazon, or e-bay.
Worked for me.
C.B.
