RV.Net Open Roads Forum: Tow Vehicles: Check you cooling stack!
Search only in Tow Vehicles
 > Check you cooling stack!
BobsYourUncle
Calgary Alberta Canada
Posted: 07/30/21 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
Bigfoot affair wrote:
BobsYourUncle wrote:
I have the same LBZ and have overheating problems too.
I suspected a plugged rad, so I had it removed and at that time had the crud blown / hosed out of the rest of the stuff in front of the rad. A multitude of bugs and other debris came out.
I didn't have the bucks for a new rad, so I put in a known good used one for now.
Everything is clean in there but my LBZ still gets dangerously hot hauling my TT up a long grade.
My next fix is a brand new rad to see if that helps. Can't believe the money they charge for stuff like this.
Just a thought, have you replaced the thermostats? One or both may be failing.
Yes, and the water pump too.
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
