RV.Net Open Roads Forum: Tow Vehicles: Ram 3500 DRW Tires
Search only in Tow Vehicles
 > Ram 3500 DRW Tires
buck n duck
Arkansas
Posted: 07/29/21 07:32am Link  |  Quote  |  Print  |  Notify Moderator
Has anyone replaced the factory 235/80R17 with 255/80R17? It looks like they are 1.2" taller and .7" wider. If so do you have plenty of space between the rear wheels?
Brian
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 07/29/21 08:31am Link  |  Quote  |  Print  |  Notify Moderator
You have to maintain the proper distance between the Duals to prevent sidewalls from touching, which is BAD.
Some add bigger tires by adding a spacer between the wheels. I think I'll keep my OEM size.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
Durb
NW
Posted: 07/29/21 08:38am Link  |  Quote  |  Print  |  Notify Moderator
I have 1" spacing between tires on my 235/80 tires. This is at 55 PSI and unloaded. Going to a larger size will reduce that to a little over 1/4" unloaded. Seems like that spacing would be perfect for catching rocks and grinding them into the sidewalls.
There is a dually that roams around our town that has monster tires that stick out around 5" past the wheel wells. I assume he has special wheels or spacers.
The 1.2" taller calculates out to 4%. That is 4% less acceleration and braking performance.
n0arp
FT
Posted: 07/29/21 09:13am Link  |  Quote  |  Print  |  Notify Moderator
Over on a Cummins-specific forum, lots of people are running 255s and as long as they keep adequate pressure in them, they don't come near touching. Personally I wouldn't, but plenty of people do. There are several threads on it over there. Some run quarter inch spacers. There are a few people who go all the way to 285s with a 1" spacer, which is getting dangerous.
If you want a bigger/wider tire, you really need to replace the wheels with something like DDC or American Force forged, and be sure to consider the weight carrying capacity. The 17x6" isn't wide enough to put a 255 on, at least according to most manufacturers I've seen, who call for a 6.5" minimum width. Some chain, or more reputable tire shops might refuse to mount them.
You could also go to 19.5s. I'm running 245/70r19.5 on 19.5x6.75" wheels. For other reasons, they're equally annoying to get mounted.
* This post was edited 07/29/21 09:36am by n0arp *
2021 Ram 5500 Limited 84CA Cummins 4x4 w/ flatbed
2020 Jeep Wrangler Unlimited Rubicon 2.0T (follow or TC toad)
2015 Keystone Alpine 3730FB 2925W/22.8kWh, 30K multi-split
2016 Arctic Fox 1140 WB 1800W/11.4kWh
Cummins12V98
on the road
Posted: 07/29/21 10:00am Link  |  Quote  |  Print  |  Notify Moderator
Taller tire means less towing capacity.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
n0arp
FT
Posted: 07/29/21 10:05am Link  |  Quote  |  Print  |  Notify Moderator
If you're talking about gearing, yes, but the impact here is relatively minimal. Otherwise, a proper wheel/tire combination could be taller and still (theoretically, for the weight police here) increase towing capacity by increasing the payload capacity.
235/80r17 = 31.8" (factory size on DRW)
255/80r17 = 33.1" (discussed here)
275/80r18 = 33.2" (factory 18 on SRW)
285/60r20 = 33.0" (factory 20 on SRW)
245/70r19.5 = 33.3" (what I run, and mentioned above in this thread)
So all things considered, going to the 255/80r17 will provide the same final drive ratio as a factory SRW with the same drivetrain/gearing. I don't consider that a big deal. Use AlfaOBD to reprogram the tire size if you want all the shift points, etc to be exact.
You could go up to a 35" with your 4.10s, and be right at 3.73 which is a very common ratio sold on Rams that tow heavy.
* This post was edited 07/29/21 04:54pm by n0arp *
SweetLou
La Quinta, CA USA
Posted: 07/30/21 07:26am Link  |  Quote  |  Print  |  Notify Moderator
But you can go faster to where you are towing [emoticon] (Mushroom cloud)
2013 3500 Cummins 6.7 Quadcab 4x4 3.73 68FE Trans, 2007 HitchHiker Discover America 329 RSB
We love our Westie
Cummins12V98
on the road
Posted: 07/31/21 09:51am Link  |  Quote  |  Print  |  Notify Moderator
COOL!!! That means my real top speed of around 103 may be 105 or so.
whjco
Lexington, KY
Posted: 08/01/21 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
Is your truck a 4 x 4? If so, you'll need to replace all six tires as they must all be the same size.
Bill J., Lexington, KY
2006 Starcraft 2500RKS 25' Travel Trailer
2015 Ram 2500 Big Horn 6.7 Cummins.
ksss
Eastern Idaho
Posted: 08/02/21 07:40am Link  |  Quote  |  Print  |  Notify Moderator
I think even a 4X2 needs the same size for the ABS to work correctly.
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
