RV.Net Open Roads Forum: General RVing Issues: Little red Honda pellet grill
 > Little red Honda pellet grill
rickhise
home
Posted: 07/30/21 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone tried using the pellet style cooker
While using a 2000 red Honda.
Thanks
dedmiston
Coast to Coast
Posted: 07/31/21 06:07am Link  |  Quote  |  Print  |  Notify Moderator
Pellet grills use very little power. There are three parts that are powered: the heating element, the auger, and the fans.
At startup, the anger turns and fills the pot with pellets. Then the heating element runs for about 45-60 seconds to ignite the pellets, and then the fans stoke the flames.
After that initial ignition, the igniter never runs again, so the only power is the small fans and the occasional use of the auger to dispense more pellets.
The whole process uses hardly any power. If you have an inverter, you won't even have to run the Honda much.
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
FlatBroke
CO/AZ
Posted: 07/31/21 06:21am Link  |  Quote  |  Print  |  Notify Moderator
Red Honda yes, blue Honda no.
Hitch Hiker
"08" 29.5 FKTG LS
goducks10
There
Posted: 07/31/21 08:42am Link  |  Quote  |  Print  |  Notify Moderator
Yes but it's overkill and noisy. Not noisy like a contractor gen but noisy in that who wants to listen to a gen run for several hours or longer?
I would invest in a 150W inverter with alligator clips and use the RV batteries to power grill. I've done that many times with my Traeger Junior. I already have an inverter so I just plugged the Traeger into the trailers outside 120V plugin.
Posted: 07/31/21 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
I haven’t, but is there a deeper question inferred here?
2017 Heartland Torque T29
Trekkar
Michigan
Posted: 08/01/21 06:27am Link  |  Quote  |  Print  |  Notify Moderator
The Green Mountain Grill Trek pellet grill runs DC instead of AC.
Very low power usage, even on long cooks.
2014 Dodge Ram 1500
2021 Salem SFX 167RBK
navigator2346
Wa and points South
Posted: 08/01/21 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
A Green Mountain Davey Crockett will run on DC so no need for a generator
dedmiston
Coast to Coast
Posted: 08/01/21 01:37pm Link  |  Quote  |  Print  |  Notify Moderator
Those GMGs are a camper's dream. I love m my two GMGs so much more than my Traeger.
StirCrazy
Kamloops, BC, Canada
Posted: 08/02/21 09:50am Link  |  Quote  |  Print  |  Notify Moderator
there the same gril, new naming structure for GMG.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
Super_Dave
Harrisville, UT
Posted: 08/06/21 08:09am Link  |  Quote  |  Print  |  Notify Moderator
Pellet grill can be hooked to a 12v battery. One can run the generator later or at anytime to recharge battery if really concerned about it.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
