RV.Net Open Roads Forum: Tow Vehicles: 2011 F250 Steering
Search only in Tow Vehicles
 > 2011 F250 Steering
danrclem
Ky.
Posted: 07/30/21 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2011 F250 with about 55,000 miles on it. When making a sharp turn it doesn't want to center the steering by itself. I have to take it all the way back to center myself. It steers very easy and really I would say too easy. Is this the way they all work or does the alignment need to be changed?
agesilaus
North Florida
Posted: 07/30/21 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
I just spent over $2K on getting my 2012 F350 4WD 6.7L front end rebuilt, hope that does not happen to you.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
Superbumper
danrclem
Ky.
Posted: 07/30/21 10:30pm Link  |  Quote  |  Print  |  Notify Moderator
I really don't think it needs a rebuild but I could be wrong. I've had it for a few years but haven't put very many miles on it. It drove the same way when I bought it. I forgot to mention that it has a 6.2.
Gooma
Iowa
Posted: 07/31/21 05:52am Link  |  Quote  |  Print  |  Notify Moderator
YES you at least need an alignment. Probably a worn or bent part. Get it done soon, before it fails completely and leaves you stranded somewhere, or worse.
theoldwizard1
SE MI
Posted: 07/31/21 09:32am Link  |  Quote  |  Print  |  Notify Moderator
The caster angle needs to be increased. If it is within spec, it is acceptable to be increased more for better centering without causing tire wear.
RAS43
Littleton,CO
Posted: 07/31/21 11:09am Link  |  Quote  |  Print  |  Notify Moderator
This!
danrclem
Ky.
Posted: 07/31/21 11:24am Link  |  Quote  |  Print  |  Notify Moderator
It tracks very good and stays straight when I let go of the steering wheel. I'll have the alignment checked and go from there.
Has anybody else had a problem like this with their Super Duty?
theoldwizard1
SE MI
Posted: 07/31/21 11:30am Link  |  Quote  |  Print  |  Notify Moderator
2WD or 4WD ?
Posted: 07/31/21 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
If it doesn’t wander and tracks well, not likely a Caster issue.
Sounds more like sticky shuttle valve in steering box maybe.
But hard to diagnose on the internet….
2017 Heartland Torque T29
danrclem
Ky.
Posted: 07/31/21 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
2WD or 4WD ?
It's a 4WD and it has the snow plow package with the heavy front springs. Everything seems to work fine except I have to bring it back to center myself.
