RV.Net Open Roads Forum: Truck Campers: Macerator pump hose
 > Macerator pump hose
Hemi Joel
Minnesota
Posted: 07/31/21 08:50am Link  |  Quote  |  Print  |  Notify Moderator
I just got a macerator pump that has a garden hose connection for the discharge,but I have not yet acquired a discharge hose. For those of you using a macerator pump what type of hose do you use? How do you store it? Thanks, Joel
2018 Eagle Cap 1163 triple slide on a 93 Dodge D350 Cummins, DTT 89 torque converter, big turbo, 3 extra main leafs, Rancho 9000s rear, Monroe gas magnums front, upper overloads removed, home made stableloads, bags.
SoonDockin
Oklahoma
Posted: 07/31/21 09:22am Link  |  Quote  |  Print  |  Notify Moderator
I had one (macerator pump) I picked up at camping world that had an attached hose. It had a cap on the end so once you were finished, you just capped it and stuff it all in the storage. Mine was on a C and the sewer connection was in a storage with all the valves. Never had to remove it.
I am not sure that helps, but it was a fairly durable hose about the size of a water hose that would extend if needed.
2019 Ford F450 KR
2018 Arctic Fox 1140 Dry Bath
theoldwizard1
SE MI
Posted: 07/31/21 09:28am Link  |  Quote  |  Print  |  Notify Moderator
Get a GOOD QUALITY rubber hose, at least 5/8" ID, 3/4" IS BETTER. The old Craftsman rubber hoses were excellent, but heavy and left black on your hands.
CA Traveler
The Western States
Posted: 07/31/21 09:50am Link  |  Quote  |  Print  |  Notify Moderator
Lots of options. https://www.amazon.com/rv-macerator-hose/s?k=rv+macerator+hose
2014 Grand Cherokee Overland
Bob
toedtoes
California
Posted: 07/31/21 01:38pm Link  |  Quote  |  Print  |  Notify Moderator
I keep my macerator at home - use a stinky slinky on the road - so I bought a solid pro grade garden hose and store it on a hose reel next to my clean out. That way I can just pull the hose out and hook up. The macerator pushes everything through the hose still left on the reel just fine.
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
Hemi Joel
Minnesota
Posted: 08/02/21 09:30pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the ideas!
