RV.Net Open Roads Forum: Truck Campers: Another noobie question.
 > Another noobie question.
Longshore
California
Posted: 07/31/21 09:23am Link  |  Quote  |  Print  |  Notify Moderator
I read some threads in the " beginning RV" dept. about traveling with the propane on to the fridge. Most of the entries are 15 years old.
I respect the knowledge and opinions expressed here. I know there are differing opinions on this subject. So do you leave the LP on while traveling? I know to shut it off before fueling, but on these hot days if I open the fridge once it takes hours to get real cold again. Turning off the gas I might as well pack an ice chest and use the fridge for storage.
Apologies if this is like the TP thread...rehashed to death...
Kayteg1
California > Nevada
Posted: 07/31/21 09:28am Link  |  Quote  |  Print  |  Notify Moderator
That topic was hot 15 years ago when trucks had smaller alternators and inverters were expensive.
The issue is that when driving with propane flame is OK, sooner or later you will forget to turn it off, or on while fueling.
Leaving it on 12V makes it bulletproof, although 12V elements deliver less cooling that good propane burner.
The dispute is even hotter in motorhomes section.
There have been several reported accidents, where flat tire took the inner fender with it and live propane tubing above.
Add spark from the rim touching the road and motorhome was totaled due propane not shut off at the tank.
So having motorhome, driving with propane off from the tank was religious.
On TC the risk is lower, when factory charging wire is not adequate for running fridge on 12V, so I used propane flame.
Yes guilty of fueling with open flame.
Lately I parted my camper and used the parts for Sprinter conversion.
Having 3-way fridge and 2-way water heater I deleted propane all together and have all operating on electric power.
WH runs on inverter, who has ignition-activated switch and when 12V on fridge turns too low, I switch it to 120V from inverter as well.
* This post was edited 07/31/21 12:04pm by Kayteg1 *
bgum
South Louisiana
Posted: 07/31/21 09:31am Link  |  Quote  |  Print  |  Notify Moderator
We run with the gas on. We try to use the first pump in a two pump isle. That way the trailer is out in the clear and not near gas fumes. If someone wants to use the second pump they can pull in ahead of us or back up to the pump. Open flame near gas fumes is dangerous.
Southern California :(
Posted: 07/31/21 10:36am Link  |  Quote  |  Print  |  Notify Moderator
Safer to drive with propane off…yes..but I drive with the fridge and propane on.
bukhrn
Lanexa, Va
Posted: 07/31/21 11:21am Link  |  Quote  |  Print  |  Notify Moderator
Fridge and propane on , except when plugged in, then Fridge and water heater on electric.
2007 Forester 2941DS
2014 Ford Focus
sbryan@vtbryans.com
Vermont
Posted: 07/31/21 11:57am Link  |  Quote  |  Print  |  Notify Moderator
Propane on when traveling. I don’t have 12 volt fridge so it is either propane or shore power. Since we have a diesel truck no issue with fumes.
Shawn
2013 Ford F350 6.7 CCLB Ruby Red SRW, sway bar, Bilsteins, etc
2007 Cyclone toyhauler, 18,000 GVWR
Northstar Igloo 9.5
https://photos.smugmug.com/photos/i-2J3zF6J/0/M/i-2J3zF6J-M.jpg
US Army retired
Posted: 07/31/21 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
^Because no one will ever spill some gas while you’re filling with diesel?
Not that I believe it’s a significant risk at all.
Traveling with propane fridge off in hot weather is basically a death sentence for your food IMO, unless you have DC mode and enough battery power to compensate.
Use the propane.
This is another ridiculous wivestale/fear that I don’t understand….honestly.
Kayteg1
California > Nevada
Posted: 07/31/21 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
Several members choose to use inverter to run the fridge.
Having build-in inverter in my F350, I was also considering to run 120V wire to the fridge, but other projects got higher priority.
Slymer
Ontario, Canada
Posted: 07/31/21 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
Fridge on propane while travelling. When fueling I find it easier to turn the fridge off than the propane at the tank. I figure with the fridge off it shuts down any spark attempt to re-light.
toedtoes
California
Posted: 07/31/21 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
Depends on the time spent on the road. If I am going for less than 4 hours, I cool it on shore power before the trip, fill it up, and drive with it turned off. When I arrive at the campground, I turn the propane on. I have found that fridge stays cold enough for that distance to not be a problem.
For drives longer than 4 hours, I run it on propane. I could run it on 12v, but I don't want to have to worry if I decide to make a stop - with 12v, I could potentially run down the tow vehicle battery during a stop.
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
