RV.Net Open Roads Forum: Truck Campers: Another noobie question.
 > Another noobie question.
JIMNLIN
Oklahoma
Posted: 07/31/21 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
Propane on since my first LP fridge in the late '60s in a truck camper. Before that we used "ICE BOXES" which meant finding a ice house for block ice. Lots of spoiled food.
Three truck campers...one TT....three 5th wheel rv trailers later no way I travel without the propane fridge on. Its on before we leave the house and turned off when we get back home.
specta
utah
Posted: 07/31/21 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
So OP, what are you going to do??
Kenny
2011 Chevy 2500 HD 6.0L 4wd
1976 Ford F-250 6.4L 4wd
Longshore
California
Posted: 08/02/21 09:21am Link  |  Quote  |  Print  |  Notify Moderator
After reading all this I'll run with the LP on to the fridge. It doesn't seem to be the hazard it was before with the newer tanks and valving.
Appreciate the opinions.
adamis
Northern California
Posted: 08/02/21 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure if it's a California thing but one thing that has changed a lot in fifteen years are the types of nozzles at gas stations. Here in California all the nozzles are required to prevent excess vapor release and so make a seal on the tank when connected to the car. Diesel doesn't have the same issue so doesn't have this feature on diesel hoses. The result of these requirements are a lot less fuel vapor floating around a station.
I am also in the camp of leave it on. The fridge can barely keep things cold as it is. On rare occasions the flame will go out while driving and that can be frustrating as the fridge struggles to catch up at camp if it is hot outside.
I'm no expert and haven't been around as long as some of the old timers on this board but I have to think the number of times a camper fridge flame caused an explosion at a gas station is probably close to zero and likely because something else was significantly wrong unrelated to the camper.
1999 F350 Dually with 7.3 Diesel
2000 Bigfoot 10.6 Camper
Kayteg1
California > Nevada
Posted: 08/02/21 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
Again, this is not just about blowing gas station.
CA bridges don't have propane restrictions, but lot of other states require propane off at the tank for tunnels, ferry and train rides.
That beside the accidents like I pictured before.
Those things do happen and happen often when you travel around.
StirCrazy
Kamloops, BC, Canada
Posted: 08/02/21 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
the only time I turn mine off is where I find thoes restrictions, for example uphere you have to turn your propne tanks off and put a tag on them for the ferry, but thats the only time I turn mine off and it gets turned on right away again when I am off.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
d3500ram
Colorado
Posted: 08/02/21 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
People will do what people do.
When I had my TC's, I would fill the diesel (all components and appliances off) a day or two before heading out.
Then at home, I would pre-cool the fridge on shore AC and pre-heat the water heater. When I was ready to travel, I would shut down the water heater for travel as it seems to retain the heat pretty well.
Depending on time of distance travel, I would generally not turn on the fridge while traveling. It seemed to keep stuff cold for a 3-4 hour travel if not opening the fridge door.
Sometimes I would travel with LP fridge going but ALWAYS turned it off before approaching the pumps. The water heater and fridge were right close to the fuel door and for the sake of safety, the extra 20 minutes or so to LP down and then LP up was not too much a price to pay for taking prudent precautions.
Sold the TC, previous owner of 2 NorthStar pop-ups & 2 Northstar Arrows...still have the truck:
2005 Dodge 3500 SRW, Qcab long bed, NV-6500, diesel, 4WD, Helwig, 9000XL,
Nitto 285/70/17 Terra Grapplers, Honda eu3000Is, custom overload spring perch spacers.
gitpicker2009
texas
Posted: 08/03/21 11:02am Link  |  Quote  |  Print  |  Notify Moderator
Mine automatically selects which source to use. If plugged into shore power, or driving, the DC option runs, when I'm boondocked, it selects propane. You can override it manually and choose, but I don't.
Kayteg1
California > Nevada
Posted: 08/03/21 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
What model is it?
The main problem on Dometic 3-way is that it is having automatic between LP and 120V, who can't be overridden, when 12V require manual switching.
That leads to situation that when you pull 120V supply with propane off at the tank, the fridge will keep on sparking for few minutes before going into limp and will not switch to 12V on its own.
I tried to rewire the switches, but they are soldered to computer board, what makes it above my skill level.
At the end I put a relay on fridge main 12V supply, who is activated by ignition, so fridge runs on 12V only when alternator is charging.
Than manual switch to turn it on when solar charging or 120V is available.
Posted: 08/03/21 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
^ Weird, both my old Dometics in mid 2000's model campers switched automatically between all 3 modes, in the correct priority.
AC was first priority if it sensed 120V power, then switched to LP automatically if no 120V and when the flame would blow out sometimes running down the highway, it would kick to 12V power. Just like clockwork.
