RV.Net Open Roads Forum: Truck Campers: Another noobie question.
 > Another noobie question.
Posted: 08/03/21 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
gitpicker2009 wrote:
Mine automatically selects which source to use. If plugged into shore power, or driving, the DC option runs, when I'm boondocked, it selects propane. You can override it manually and choose, but I don't.
That sounds horrible. DC/LP that defaults to running down your batteries while you're driving.
How does it know if you're driving or parked? Motion sensor?
If you stop at a gas station, does it immediately try lighting the LP flame while you're pulled up to the pump?
I think your confused or didn't state how it works clearly...
2017 Heartland Torque T29
specta
utah
Posted: 08/03/21 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
I just went out and unplugged my camper from 110v and shut off the LP, it did not switch to DC by itself but my camper is older, I wouldn't doubt that the newer ones do.
I always travel with my fridge running in LP. Its on the opposite side of the truck's the fuel door so I never worry about it.
It I were to travel through tunnels where they require you to shut them off I would most certainly do that and switch it to DC until I exited the tunnel.
Kenny
2011 Chevy 2500 HD 6.0L 4wd
specta
utah
Posted: 08/03/21 01:31pm Link  |  Quote  |  Print  |  Notify Moderator
Kayteg1 wrote:
The main problem on Dometic 3-way is that it is having automatic between LP and 120V, who can't be overridden ????, when 12V require manual switching.
When I plug into 110v it automatically switched from LP to 110 but I can manually switch it back to LP.
Or did I misunderstand your statement?
d3500ram
Colorado
Posted: 08/03/21 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
Mine did the same.
