RV.Net Open Roads Forum: Tech Issues: Time to swap the Refrigerator?
 > Time to swap the Refrigerator?
SoonDockin
Oklahoma
Posted: 07/31/21 09:56am Link  |  Quote  |  Print  |  Notify Moderator
I rarely find a level place to park. For the first couple of years, I had no issues with my refrigerator. This year it seems to be quite finicky. I am planning to add several lifepo4 batteries and it might be time to think AC/DC compressor vs my propane/AC norcold.
Any advice or suggestions?
2019 Ford F450 KR
2018 Arctic Fox 1140 Dry Bath
Monterey, California
Posted: 07/31/21 10:33am Link  |  Quote  |  Print  |  Notify Moderator
With Lithium batteries and solar I do think it’s time for you to consider switching to a 12 volt fridge. It’s on my horizon.
2oldman
NM
Posted: 07/31/21 10:42am Link  |  Quote  |  Print  |  Notify Moderator
You camp unlevel?
theoldwizard1
SE MI
Posted: 07/31/21 11:26am Link  |  Quote  |  Print  |  Notify Moderator
I will never own another RV that does not have a compressor refrigerator ! Whether it is AC only DC doe not matter much to me.
eric1514
AZ ID
I swapped the absorption fridge in my van to a NovaKool compressor and I will do in my class c even without lithium batteries. It’s night and day if you do it right, and the factories rarely do. You might also see if J.C. Refrigeration makes a conversion kit for your present unit. That’s the route I’m going in my c because the present fridge fits so well and ‘d have to remove a window to get it out.
2006 Isata Touring Sedan 250
Posted: 07/31/21 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
2oldman wrote:
You camp unlevel?
Camp or park?
Can see where parking somewhere for a day could be an issue but TC on truck is pretty easy to level up in my experience.
But these threads are useless without parameters.
Un level like on a 4:1 slope or un level like 3 deg off.
2017 Heartland Torque T29
Posted: 07/31/21 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
I’ve never owned an AF camper that was less than about 10 years old and the fridges always worked fine, so maybe it just needs repair?
2oldman
NM
Posted: 07/31/21 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
My Dometic gas refer works just fine. I don't see the need to have to feed electricity to a compressor.
2oldman
NM
Posted: 07/31/21 01:29pm Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
2oldman wrote:
You camp unlevel?
Camp or park?
Perhaps I misunderstood that meant a campsite. If just for intermittent parking, simply turn off the gas refer.
SoonDockin
Oklahoma
Posted: 07/31/21 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
2oldman wrote:
You camp unlevel?
I will confess, I never cared if I was off level when camping. Ya I get close but never bother blocking tires or running jacks down. I had a class C with a 7cu/ft dometic fridge that never gave me a bit of problems and I never tried to level that rig.
I had read that they needed to be level, but just assumed that was a "suggestion".
I spent this trip measuring every low storage spot to see just how many Ah I could fit. Seems like I can easily add 600Ah and only use up one storage hatch. I can probably fit 4-500 watts of solar on the roof, and my truck has the super duper alternator for charging on the road. We often camp in RV parks so charging batteries each night is easy. We like to go explore and on this trip visiting my kid in Colorado, we use it for everything. Probably ran the generator in places it was frowned on but when you need a microwave .....
The fridge is a big problem right now. It was hit and miss if it would cool, and clearly needs attention. As it does not use DC, I will be looking at the suggested retrofit options, and if necessary will replace it.
I would also like to lessen my need for propane. I have two 30lb bottles that are a bit heavy to lift that high. I would prefer to gt by with one or two 20lb bottles.
Thanks for all the support!
* This post was edited 07/31/21 09:15pm by SoonDockin *
