RV.Net Open Roads Forum: Fifth-Wheels: Alternatives for Michelin XPS Ribs?
 > Alternatives for Michelin XPS Ribs?
mileshuff
Phoenix, AZ.
Posted: 07/31/21 10:36am Link  |  Quote  |  Print  |  Notify Moderator
Currently have XPS Ribs on my 5th wheel. Great tire but they are now 7 years old. Tons of tread left but feel 7 years is pushing my luck.
Looking to replace but XPS Ribs are costly. Are there cheaper alternatives that are just as reliable? Have had blow outs with factory china bombs. They don't last long here in the hot desert southwest.
What about Bridgestone Duravis (not sure which model), or possibly Maxxis? What else?
2014 Winnebago 26FWRKS 5th Wheel
2007.5 Dodge 2500 6.7L Diesel
2004 Dodge Durango Hemi 3.55 (Used to tow TT)
agesilaus
North Florida
Posted: 07/31/21 11:08am Link  |  Quote  |  Print  |  Notify Moderator
I'm using Goodrich Commercials LT tires. Work great, have great reviews and are a lot cheaper.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
theoldwizard1
SE MI
Posted: 07/31/21 11:24am Link  |  Quote  |  Print  |  Notify Moderator
Do you have deep cracks/checks in the side walls ? If NOT, keep on driving !
phillyg
SWFL
Posted: 07/31/21 11:27am Link  |  Quote  |  Print  |  Notify Moderator
For that light weight FW, you should look at GY Endurance. Sailun or another G-rated tire would be overkill, IMHO. I've seen lots of reports of Maxxis failures.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
JIMNLIN
Oklahoma
Posted: 07/31/21 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
The XPS Ribs are a 16" LT E commercial grade all steel ply carcass and tread and come in a 3042 lbs and a 2680 lb load capacities.
The Bridgestone R-238 are same sizes same commercial grade all steel ply carcass 16" LT E tires. Both are tops for trailer use with 6k and 5k axles.
Maxxis and Endurance are just another poly carcass ST class tire.
My '97 11200 lb 5th wheel trailer is old and lots of miles. I've used two sets of BFG Commercial T/A 2 16" LT215/85-16 E @ 2680 lbs. First set ran to the wear bars at 55k miles/7 years and second set around 53k miles with no issues.
The OPs 26' fwrks 5th wheel on the net has a 10500 lb gvwr. The 16" LT E at 3042 lbs capacity or 2680 lbs capacity has plenty of capacity and reserve for that size trailer.
azdryheat
Tucson, AZ
Posted: 07/31/21 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
Why change what's working for you? I love my Ribs.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
TravelinDog
Nevada
Posted: 07/31/21 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
Why even look at cheap alternatives? Tires on my truck or RV are not anything I would skimp on, too much at risk.
BB_TX
McKinney, Texas
Posted: 07/31/21 03:08pm Link  |  Quote  |  Print  |  Notify Moderator
Michelin says inspect its tires yearly beginning at 5 yrs and replace at 10. I don’t know any others that give that long of a life span. I ran my last set of Ribs to 9 yrs still looking practically new and replaced with another set.
Splashers3
Oakville, MD
Posted: 07/31/21 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
I got 9 years out of my RIBS before one blew just sitting in my driveway.....luckily no damage....it was just as I had already made a deal on my current 5ver...so they got a brand new set of tires. I could not risk an interstate blowout on the way to Couch's....otherwise my trade-in might not have been.
My current 5ver has "G" rated tires and unfortunately, Michelin does make a XPS RIB in that size....I wonder why?
2017 GMC 3500 Sierra Denali, C/C, D/A, DRW, w/40gal Aux tank, 18K B&W Patriot.
2019 Cedar Creek Hathaway, 34RL2 - w/Bells & Whistles and disc brakes
Traded 2009 Cedar Creek Silverback, GII, 32 WRL
laknox
Arizona
Posted: 07/31/21 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
The current Duravis is the R238. $260 at Discount for 235/85-16.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 63 Year Member
