RV.Net Open Roads Forum: Fifth-Wheels: Alternatives for Michelin XPS Ribs?
 > Alternatives for Michelin XPS Ribs?
jjj
Lancaster,Ca.U.S.A.
Posted: 07/31/21 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
Friend of mine bought goodyear endurance and loves them. 3 years and no problems. He pulls a 35 ft cougar pull trailer.
2002 F-350 Crew-Cab Dually
V-10-4.30 gears Mag-Hytec diff.cover
w/Amsoil-6.0 trans cooler Curt Q5 20K hitch & bedsaver
2005 Keystone Challenger 34TBH-Fifth Airbourn
jaycocamprs
Ringgold Georgia
Posted: 07/31/21 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
mileshuff wrote:
Currently have XPS Ribs on my 5th wheel. Great tire but they are now 7 years old. Tons of tread left but feel 7 years is pushing my luck.
Looking to replace but XPS Ribs are costly. Are there cheaper alternatives that are just as reliable? Have had blow outs with factory china bombs. They don't last long here in the hot desert southwest.
What about Bridgestone Duravis (not sure which model), or possibly Maxxis? What else?
The Bridgestone Duravis R-238 is as good a tire, but won't be much if any cheaper. With a 10.5K GVWR I'd likely go with the the poly LT, or just spend the coin. We run about 12K with 14.4K GVWR. When we replaced the Bridgestone Duravis R-250's I went to Sailuns. Still overkill, but after 3 year I'd do it again.
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
Cummins12V98
on the road
Posted: 07/31/21 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
Many stories just like this and at a reasonable price. Made in a free Country.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Thermoguy
Graham, WA
Posted: 08/01/21 10:45am Link  |  Quote  |  Print  |  Notify Moderator
I'm running a Goodyear Wrangler LT E Truck tire on both my trailers. Plenty of weight capability for a trailer of your size. No need to get a G rated tire. Similar to the XPS, a truck tire is a great tire for trailers with more testing and more capability than most trailer tires. ST tires don't go through the manufacturer testing like the LT tires.
handsome51
Baytown
Posted: 08/01/21 08:20pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2006 Carriage 5th wheel I bought new. The china tires lasted 7000 miles. I was lucky and caught them before a blow out. I have been using the XPS Ribs ever since. Yes they are costly , but are good tires. What ever you pay for the tires is cheaper then fixing your RV after a blow out. And you still have to buy a new tire.
CALandLIN
SC
Posted: 08/02/21 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
Your trailer's OE tire size was ST225/75R15. Many of the ST tire manufacturers now provide that size with a steel cased LRF.
Carlisle is one of them.
Carlisle All Steel
Endricken
Alabama
Posted: 08/02/21 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
I took my sole 7 year old XPS Rib to a tire dealer as is had very slight cracking this Spring
His inspection did NOT leave him wanting to sell me a new tire!
So I put it back on the Fiver…..
I’m running Bridgestone Duravis on the other axle
I lost one XPS Rib to a nail on a IL Tollway Tollbooth ramp! Thanks IL Tollway??
Retired USAF
Silver 05 Dodge RAM LB CTD Dually 4Speed Auto SWD 3.73, Westin Sportsman Grill & Taillight Guards,Husky Mudguards, Retractable Ball Hitch, Onboard Air & Horns, MaxBrake - towing 2005 Keystone Montana Big Sky 3670 with Star Performance adapter
mileshuff
Phoenix, AZ.
Posted: 08/26/21 10:17pm Link  |  Quote  |  Print  |  Notify Moderator
OE tire is 16" on the 2014 26FWRKS. I believe they changed to 15" in 2015 and later along with a lower rated axle. Glad I got the 2014!
2014 Winnebago 26FWRKS 5th Wheel
2007.5 Dodge 2500 6.7L Diesel
2004 Dodge Durango Hemi 3.55 (Used to tow TT)
laknox
Arizona
Posted: 08/27/21 09:28pm Link  |  Quote  |  Print  |  Notify Moderator
Carlisle All Steel
That's a 16" tire, not 15".
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 63 Year Member
laknox
Arizona
Posted: 08/27/21 09:31pm Link  |  Quote  |  Print  |  Notify Moderator
I ended up getting Endurance E's because the Carlisle HDs were not available at Discount Tire and I needed tires within 48 hours due to a semi-unplanned trip. So far, they're OK, but it was only 130 miles. FWIW, Discount refused to air my tires below the rated 80 psi. I wanted 70.
Lyle
