RV.Net Open Roads Forum: Tech Issues: Dashboard Alternator light
 > Dashboard Alternator light
Page of 8
eric1514
AZ ID
Posted: 07/31/21 10:37am Link  |  Quote  |  Print  |  Notify Moderator
Hi all,
The MPPT controller on my coach will deliver 14.6 volts in bulk mode which is fine. In fact it’s exactly what the specs on my GC2 house batteries call for. But when I turn on the engine and the system connects the coach and starter batteries together, the dashboard alternator light will illuminate, presumably because Ford thinks 14.6v is to high.
Couple of questions. Do I care? As far as I know, 14.6v is not excessive and the condition should only last a couple of hours until the charger drops to absorbtion mode and a lower voltage. Or, is there an easy way to reprogram the light or turn it off completely? I’m monitoring all the batteries while I travel with an app constantly running on an old cell phone so I know what’s going on without an idiot light. I can change the profile of the charger to a different battery type and lower the voltage to 14.2v but I don’t wanna if I don’t have to.
TIA,
Eric
2006 Isata Touring Sedan 250
RLS7201
Posted: 07/31/21 11:47am Link  |  Quote  |  Print  |  Notify Moderator
I have experienced the same issue as you. I just turn off the solar when traveling and let the alternator do it's job.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
RLS7201
Posted: 07/31/21 11:49am Link  |  Quote  |  Print  |  Notify Moderator
oops
Richard
BFL13
Victoria, BC
Posted: 07/31/21 11:50am Link  |  Quote  |  Print  |  Notify Moderator
It is not the voltage as such, but something is wrong. First try it with no solar connected to the house batts.
Is the controller chassis grounded to the RV frame? If so disconnect that. Perhaps there is a polarity problem with how it is all wired and that is what the dash light is not liking. ( WAG) . Anyway the solar and alternator charging should play well together. Something is wrong with your wiring of the solar and the isolator outputs most likely. IMO suspect the solar installation, as the RV will be ok if as built.
IMO don't drive around much like that until it is fixed.
One thing to expect is that on the house batts if solar gives you 10 amps at 14.6 and alternator gives you 10 amps at 13.8 doing it one at a time, you will not get 20 amps with both on. You might get more like 10 from the solar and 5 from the alternator with its lower voltage. but that is not the issue here.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
eric1514
AZ ID
Posted: 07/31/21 01:22pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks all,
If I turn off the panels, the problem goes away.
The panels/controller work great when the engine is off.
The controller is mounted to a piece of plywood so not grounded and the feeds from the controller go to separate buss bars, positive and negative. The positive buss has a cable that connects to the positive battery bank post and the negative buss has a cable that connects to a shunt and the shunt then connects to the batteries.
When this happened, I just shut off the panels. My schedule hasn’t allowed me to experiment but I have a feeling that if I change the battery profile to something like GEL, the max voltage output will be 14.2. This is not my first solar install and I don’t think it’s messed up. I think it’s either a problem with the isolator or the light is showing me over voltage.
I agree. They should play nicer together. I know I’ll have to run more tests.
eric1514
AZ ID
Posted: 07/31/21 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
Richard
Thanks
This works, but I put the solar up to help the alternator. I have a large battery bank and it takes a hell of a lot of driving to replace 150 or so Ahs with just the alternator.
BFL13
Victoria, BC
Posted: 07/31/21 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
I am guessing some mix-up in the way it is all connected where somehow the solar is opening a breaker or switch
AFAIK the dash light does not indicate over-voltage, but indicates no charging is happening at the engine battery. With the light on, you could check the engine battery's voltage, turning the headlights on.
Do you also have a dash switch for using the house batts to start the engine? My class C does not, only has the isolator with ignition run to it. Some have a three switch affair for that, where the run circuit to the isolator gets there a different way. Don't know if that could be in backwards.
Maybe something is on a buss that shouldn't be with the others on it.
* This post was edited 07/31/21 01:55pm by BFL13 *
eric1514
AZ ID
Posted: 07/31/21 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
I have a boost switch, but I’m not sure it’s wired correctly. I’m not the original owner. I have noticed when I push the boost button, the relay doesn’t click.
That’s a good clue, thanks. I think I’ll disconnect the switch entirely and see what happens, but it may be a while until I get the chance.
Are you 100% sure the light does not indicate an overcharge? That was my first guess.
Thanks,
Eric
theoldwizard1
SE MI
Posted: 07/31/21 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
eric1514 wrote:
... presumably because Ford thinks 14.6v is to high.
Actually the PCM controls the voltage and yes, 14.6V is too high.
First, confirm the voltage at the vehicle battery with the trailer and solar. Now disconnect the trailer. I'll bet it is about 13.2V.
High voltage will shorten the vehicle battery life.
BFL13
Victoria, BC
Posted: 07/31/21 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
Not 100% sure, but 14.6 is not over-voltage. It will be about that at first and then taper once you get going and it all warms up, riding around 14 or a bit under that. IMO with that light on with the solar on, check the engine batt's voltage with your multimeter to see if it is getting any charging at all.
If not, then you can't drive very far like that.
Drew E on here would know about all to do with booster switches and run circuits etc. Others too.
Page of 8
