RV.Net Open Roads Forum: Tech Issues: Dashboard Alternator light
 > Dashboard Alternator light
Page of 8
MrWizard
Traveling
Posted: 08/08/21 04:42am Link  |  Quote  |  Print  |  Notify Moderator
Eric1514..Ok , I'm on page 5 of 7,
Find the heavy battery cable that goes from the Intellitec to the house batteries, find the most convenient spot in that cable run to cut it and in insert a 200 amp DC circuit breaker, the marine style have push button that opens the breaker contacts so it acts like a switch, and a lever reset that closes them, this will be manually operated by you the driver when travelling, these are very reliable and can removed or replaced easily if there is ever a need to do so
I can explain it to you.
But I Can Not understand it for you !
1997 F53 Bounder 36s
eric1514
AZ ID
Posted: 08/08/21 08:00am Link  |  Quote  |  Print  |  Notify Moderator
Or I could put a switch on one of the two small leads running to the isolation solenoid as Pianotuna suggested. But either way, I would be losing the alternator's contribution to charging the house batteries while traveling and amps is amps.
2006 Isata Touring Sedan 250
eric1514
AZ ID
Posted: 08/08/21 08:03am Link  |  Quote  |  Print  |  Notify Moderator
BFL13 wrote:
This only happens when the batts are nearly full. If they are low when starting out, you can set the controller to 14.6 and unless they get nearly full while driving, no light. Unless there is still some sun or if gen is allowed on arrival that's as high as it gets that day.
You real problem is getting them full while driving when starting low. Your alternator charging will be lamed by the solar's higher voltage, but it has low amps. You need lots of amps to get them up before arrival at the next site.
Your best amps would be from gen charging with a high amp converter. But high amps gets you to Vabs sooner at a lower SOC so the light comes on, and stays on during the Absorption the rest of the way there.
You could isolate the engine batt, and go with a high amp converter off the gen with solar added by setting solar and converter to the same high voltage. With a DC-DC you could have three chargers adding their amps and no light.
Your only limit is the gen watts as to how big an amp converter it can run, and to have the converter voltage adjustable. So toss the PD unless it is as high amp as the gen can run, and get an adjusatble voltage PowerMax LK model with as high amps as the gen can do. Set it to 14.6, the solar to 14.6, and any Dc-Dc to 14.6.
Note that a PowerMax 75 amper pulls 1700VA set to 14.6v doing 75 amps on a low battery. If your built -in gen is one of those non-inverter types it will likely not run as high an amp converter as an inverter-gen of the same |"watts" (acting more like it is MSW -it is not but it acts in a similar way for this exercise), so it can get tricky picking how big an amp converter you can run. The PowerMax 100 amper is PF corrected so it can be run by almost the same inverter-gen as the 75 amper which is not PF corrected. A Honda 2200 portable does 1800VA but my B&S 2200 does 1700VA. Gotta watch out when running things to the max you can get away with.
Of course it is no good having a converter with too high an amps that you can't run it at home on an extension cord, but only off your RV gen. BTDT. Have to have a lower amp portable charger to do the RV at home. Keeps you busy making sure you are using the right charger for where you are.
Or just accept a lower amp charging rate while driving and get by somehow with however full the batts get on arrival.
I think I'll give up RVing and take up something simpler like rocket science.
I've learned a lot since I started this and I think the ultimate solution is to install B2B charger like Pianotuna suggested many posts ago.
What I once saw as a daunting task, is really simple. If I were to buy the non-isolated version of Victron's charger I would only need to remove my isolation solenoid and add one wire, a wire from a good chassis ground up to the unit. I could probably wire in a Trik-L-Start like you would if you had a iso. solenoid. I would probably wire in a switch instead of relying on auto voltage sensing so I could turn the thing off if I though my alternator needed a rest.
Thanks all for your contributions in this thread. It's been an education.
BFL13
Victoria, BC
Posted: 08/08/21 09:04am Link  |  Quote  |  Print  |  Notify Moderator
Your alternator amps are lamed by any higher voltage charger also on the house batts, so you are not getting so many alternator amps anyway.
You can test for that with low house batts. Have the monitor on the house set to amps. See the solar amps engine off, see the alternator amps solar off, engine on AND warmed up, then see the total amps solar on, engine on warmed up.
See the amps reading on the solar controller's display, subtract from total seen on the monitor, and that is your alternator amps.
You have four 6s and say, " The only issue was it took forever to replenish the batteries if I boondocked and used 150 Ah up"
You could use 120 amps on that in Bulk, but how many amps do you need to be at say 90% SOC on arrival? How long is the drive? 150/450 is 67% SOC, so it is a "67-90".
You could do that in under two hours starting at 120 amps but if the drive is four hours you don't need so many amps. You don't halve the amps and double the time--it is not linear. But at 70 amps it would only take maybe half an hour longer. Whatever, call it three hours and you have an hour left. what if it is a five hour drive?
You can drive all day and night trying to do the 90-100 so forget that.
If you shoot for 70 amps total starting at 67% SOC, and you get 55 amps from the converter off gen, you need 15 more amps. Solar might average 5 amps or whatever for the time of day and conditions, so all you need now is 10 more amps. Is a Dc-Dc going to be worth it? How many amps of a DC is needed limited by what it will pull from 1/3 the alternator spec amps?
So IMO do some math like that before spending million$ on improving the charging set-up. You might be ok even with what you have installed now doing solar and the PD.
* This post was edited 08/08/21 09:46am by BFL13 *
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
Page of 8
