RV.Net Open Roads Forum: Why do I keep blowing out tires on my truck?
Search only in Tow Vehicles
 > Why do I keep blowing out tires on my truck?
Page of 9
mileshuff
Phoenix, AZ.
Posted: 07/31/21 12:35pm Link  |  Print  |  Notify Moderator
theoldwizard1 wrote:
From what I can find online, the standard tire size for your truck is 265/75R16. The standard Defender weight rating is is 2756 lbs/tire. There is an LT265R16 (load range E - 10 ply rating) version that is 3415 lbs/tire.
They also make a LT285/75R16 version that is 3750 lbs/tire. After multiple blowouts I would want these !
Inflate to the pressure recommended by the TIRE MANUFACTURER !
All tires have been factory size at LT265/70R17. All have been E rated 10 ply. Current LTX M/S are rated at 3195 lb at 80 PSI. Very similar to the other tires I've had.
2014 Winnebago 26FWRKS 5th Wheel
2007.5 Dodge 2500 6.7L Diesel
2004 Dodge Durango Hemi 3.55 (Used to tow TT)
mileshuff
Phoenix, AZ.
Posted: 07/31/21 12:37pm Link  |  Print  |  Notify Moderator
RAS43 wrote:
Is there somewhere you go on a regular basis that could cause damage to that RR tire, a curb, rock, etc ?
Nope. Almost all highway towing miles. Possibly how it is normally parked with sun shining on it.
mileshuff
Phoenix, AZ.
Posted: 07/31/21 12:39pm Link  |  Print  |  Notify Moderator
fj12ryder wrote:
What caused the blowouts? Tread separation, sidewall blowout, or other stuff? May be time for a cheap TPMS to see what that tire is doing.
Tread separation all three times. I check tire pressure and adjust if needed before every trip. I set them to the max rated at 80 PSI.
Posted: 07/31/21 12:43pm Link  |  Print  |  Notify Moderator
Stop buying Michiblows….next caller please!
2017 Heartland Torque T29
Posted: 07/31/21 12:51pm Link  |  Print  |  Notify Moderator
And with Michilubes propensity for cracking, turn your truck around so you’re not baking the same tires all the time.
Many folks don’t seem to know any better, but the AZ sun (or similar SW locations) is the most brutal treatment anyone can give their vehicles or toys.
There’s a reason that the houses are ALL stucco with tile roofs. Anything that is basically not made of rock or cement or dirt WILL degrade quicker or much quicker than other environments.
* This post was edited 07/31/21 01:04pm by Grit dog *
fj12ryder
Platte City, MO
Posted: 07/31/21 01:38pm Link  |  Print  |  Notify Moderator
With tread separation every time, I would be looking at an inherent problem with that corner of the truck. Bad shock allowing the tire to bounce at a high enough frequency you wouldn't necessarily feel it. I'd be looking for something that causing that tire to bounce/wobble/run out of round, or something along those lines. Maybe even check the wheel temp for a dragging brake, but that seems pretty unlikely as you'd be changing pads more frequently.
Maybe get someone to drive beside you on the highway at varying speeds to see if they can spot an issue. Just a thought.
Howard and Peggy
"Don't Panic"
theoldwizard1
SE MI
Posted: 07/31/21 01:49pm Link  |  Print  |  Notify Moderator
You still need to verify the weight on the rear axle !
Seems odd, but you may have to shift to 16" rims and LT 285/75R16 tires which have a higher payload.
What does the door sticker say for tire pressure ? If you are filling them to 80 psi cold, they will be running more than that hot !
Monterey, California
Posted: 07/31/21 02:06pm Link  |  Print  |  Notify Moderator
Isn’t the door sticker always a cold inflation pressure?
time2roll
Posted: 07/31/21 04:04pm Link  |  Print  |  Notify Moderator
Assuming your truck would indicate low pressure from a road hazard before the tire overheated and lost the tread..... the tire is defective.
I recommend switching to top line Goodyear Wrangler® All-Terrain Adventure With Kevlar®
https://www.goodyear.com/en-US/tires/wrangler-all-terrain-adventure
675w Solar pictures back up
ScottG
Bothell Wa.
Posted: 07/31/21 04:22pm Link  |  Print  |  Notify Moderator
Again, no to 16" wheels. They WONT FIT over the brakes.
Page of 9
