RV.Net Open Roads Forum: Truck Campers: New lpg tank
 > New lpg tank
mattyj
Long Island.New York
Posted: 07/31/21 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
Anyone know the proper procedure to purge brand new propane tanks? My wife brought a tank in to be filled, it is brand new and she had to leave to go get cash because their ATM does not work when she came back the girl had the propane tank all the way in the back of the yard She said it has a hole and was leaking but I think it was not purged for an initial Fillup.Does anybody know the symptoms of filling up and on purged brand new LPG tank?
2006 Ford F 350, 6.0 PSD 8 Foot Bed 4x4 with Torklift Tie downs and Stable Loads 2004 Lancelite 835 ,a/c ,electric jacks , conveince/all weather packages
CA Traveler
The Western States
Posted: 07/31/21 02:27pm Link  |  Quote  |  Print  |  Notify Moderator
Take it to a propane dealer.
2014 Grand Cherokee Overland
Bob
NRALIFR
Truck Camping Out West
Posted: 07/31/21 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
Copy/Paste from HERE
Proper Purging of a Propane Tank
Posted on 7th Jun 2019
Proper Purging of a Propane Tank is very Important!
DOT Cylinder Purging Procedure:
Exhaust to atmosphere any air pressure in the container*
Pressurize the cylinder to 15 psig with propane vapor. Never use liquid propane.
Exhaust vapor to atmosphere
Repeat four more times
SAFETY WARNING: The purging procedure should be done by a qualified trained person. Exhausting propane vapor incorrectly could result in ignition of exhausted propane fumes resulting in burn injury or death!
Why is purging a new propane tank so important?
If the natural volume of air inside your tank is not removed prior to the 1st filling, these problems will result:
During the warmer months of the year your tank could experience excessive and false container pressures. This could cause the safety relief valve to open, blowing off (discharging) the excessive pressure.
Any air mixture in the vapor space of the tank will be carried to the appliance burner. This could result in unwanted service calls from pilot light outage or improper burner flame function.
However, if the atmospheric air inside your new tank is properly purged:
The storage tank will fill faster, your appliances will function more consistently, pressure relief valves on your tank will be less likely to discharge.
WARNING! Never Purge with Liquid Propane!
Purging with liquid propane causes the liquid propane being pumped into your tank to flash into vapor, chilling the container and condensing any moisture vapor on the walls of the tank where it remains while the pressure is being blown down. Additionally, less than 50% or as little as 25% of the air will be removed if the purging is done with liquid propane.
[emoticon][emoticon]
2001 Lance 1121 on a 2016 F450
mattyj
Posted: 07/31/21 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
I got it purged from the dealer, thank you for your responses!!
Kayteg1
California > Nevada
Posted: 07/31/21 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
Never did the purge even I had valves replaced by propane dealer.
When you are filling the propane with bleeder open, the liquid is pushing about 80% of vapor out.
Propane is heavier than air, so the air is 1st to escape the cylinder with bleeder on top.
MitchF150
Puyallup, WA
Posted: 07/31/21 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
As long as you tell the propane place that 'it's a new tank and needs to be purged', they should know what to do.. If they don't, then go someplace else.
I don't think it's anything special, but the put those stickers on new cylinders for a reason..
It's been awhile since I got a new cylinder, and I'm old, so don't recall all the details, but the places I took it to did whatever they needed to do and the cylinder worked fine after that.
Good luck! Mitch
jimh425
Western MT
Posted: 07/31/21 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
This is kind of interesting to me. I never knew purging was required, but I also have never bought an empty new propane tank.
Kayteg1
California > Nevada
Posted: 07/31/21 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
I also never changed tire air from summer to winter blend.
Buzzcut1
Norcal
Posted: 07/31/21 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
I get my New/used tanks by getting a propane exchange tank once every few years.....I know, I'm bad but..........
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 08 Lance 1055, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
Posted: 07/31/21 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
!!!! Best post of the week!
Thank you for the levity!
2017 Heartland Torque T29
 > New lpg tank
